Results 1 to 5 of 5
Thread: 88C temp switch P/N?
    Sep 2017
    Vienna, VA
    1995 525i E34 6-speed
    Hey,
    Doing my own electric fan conversion (DIY write-up included) and wanted to know what the P/N is for the low temp aux fan switch that screws into the side of the radiator. I have searched realOEM to no avail.
    Thanks,
    Singing6
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    61 31 8 361 787 Radiator Fan Switch - 3 Prong - 80/88 degree
    The standard one is Radiator Fan Switch - 3 Prong - 91/99 degree Part # : 61 31 1 378 073
    https://www.ecstuning.com/b-genuine-...c/61318361787/
    you have to check in the ETK under E36 or Z3, there 61318361787 is used
    Sep 2017
    Vienna, VA
    Thanks a bunch!
    May 2017
    Perth, Western Australia
    09/90 E34 525i (M50)
    I'm really interested in how you plan to wire it. I have an electric fan that my PO installed that uses a bulb in the rad hose, he also removed that switch because idiot PO
    I bought the lower temp switch to fit thinking one day I'll fix the electric fan conversion neatly , ie removing his bulb, capillary and external thermostat and somehow wire it to that switch.
    I've looked at the relay box for the aux fans and thought if worst comes to it there's a spare spot for another relay (for my existing one) there. My biggest problem has been I don't want the factory aux fan to run on low at the same time as the aftermarket rad fan as it won't be necessary, and don't want to disable the low speed aux fan for air con purposes.
    I'm still thinking about 'how'. I've been putting it off for ages but if I have to replace my thermostat and overflow tank for unrelated issues anyway then now is the time to work something out permanently and get rid of the bulb relay, capillary and thermostat hanging off the firewall.
    I used the same pn as shogun listed but it was ~$30 elsewhere.
    Jan 2002
    Dallas, TX
    I did a Taurus fan mod on my old '95 540i using a volvo electric fan relay. Use the stock radiator temp switch.
    1995 540i/6
    2017 Hellcat Charger
  1. temp switch plug problem.. please help!!!
    By MMNJTWA in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-08-2004, 08:33 AM
  2. problem with temp switch?????? help!!!
    By MMNJTWA in forum 1992 - 1999 M3 (E36)
    Last Post: 01-07-2004, 06:26 PM
  3. Aux. Fan / Temp Switch
    By G.J. Dixon in forum 1975 - 1983 (E21)
    Last Post: 06-08-2003, 07:29 PM
  4. FS or trade: 80/88c fan switch
    By fast4d in forum BMW Parts For Sale
    Last Post: 06-24-2002, 04:16 PM
  5. 95 80/88c fan switch for sale or trade!
    By kitwetzler in forum BMW Parts For Sale
    Last Post: 04-18-2002, 11:46 PM
