Results 1 to 5 of 5
Thread: Bimmerworld E36 non-M spherical endlinks
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    For those running these endlinks on the front sway bar, how long do they last for you before they seize up?
    I've had mine on my car for 2 years now, maybe 6k miles and zero salt. It does get driven in the rain though. I've replaced one heim joint, but now the other three are also seized up. Not frozen solid, but not as free as the new one I have. Should I not worry at all since the suspension forces will far overpower the resistance of my "seized" joints?
    Aug 2012
    Central, MD
    1995 M3
    I have (homemade) spherical endlinks, and have never had one seize. Mine wear and start to get a little slack in the joint, which I don't rush to replace. When they start getting noisy (clink clink over bumps) is when I tend to replace them, I think that's about every 50 or so track days.
    MINIz guy's Avatar
    Bear, DE
    rolls coal
    Hmm, I thought the purpose of the spherical endlinks is so they don't fail as often as the stock rubber ones? I would say I have 50 days of track time; it was 2-years of autocross and a handful of track events.
    I should just start buying the replacement parts from McMaster. Will be much easier than ordering from Bimmerworld every time.
    Aug 2012
    Central, MD
    1995 M3
    Cause race parts.
    Well made rubber bushings will almost always outlast non-lubricated, non-protected spherical metal to metal joints. The advantage of metal spherical is that there's less play.
    McMaster is my go to also.
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    I had some PowerGrid endlinks that used an OEM-like ball joint. They wore out after less than two seasons. I've had the Bimmerworld endlinks with the big sphericals for a season and they're still good so far. My biggest gripe though is that they use a 3/8" rod end and a metal bushing to adapt to the 10mm hole in the strut. It's a pain in the ass, i wish they just used metric endlinks. (The Powergrids had proper 10mm studs).
  1. E36 FS: Brand new Bimmerworld brake duct kit for E36 M3 (and E36 non M).
    By SR20Fastback in forum Race Cars & Track Parts
    Last Post: 08-24-2011, 08:13 AM
  2. E36 E36 non M swaybar endlinks and support bracket
    By 99GREENM3 in forum BMW Parts Wanted
    Last Post: 05-02-2010, 10:19 AM
  3. WTB: stock E36 non-M front endlinks
    By tonyluvsilvia in forum New York / New Jersey / Connecticut
    Last Post: 06-20-2009, 02:56 PM
  4. E36 Non-M Swaybar Endlinks
    By LAWLence in forum Suspensions, Springs & Shocks
    Last Post: 07-25-2008, 12:54 PM
  5. Bimmerworld Brake Cooling Kit (E36 Non-M)
    By Deadphan in forum Race Cars & Track Parts
    Last Post: 07-31-2006, 10:57 PM
