Results 1 to 12 of 12
Thread: Heads and differences
    Aug 2016
    EastCoast
    2001 740i
    Can I use a 200 casting head on a 325ix 89? What’s the difference between it and the 885 head?
    Regina, Sask, Canada
    82 320i 89 325i
    it's super restrictive, has the smallest crappiest combustion chamber, and will destroy itself if not mated with the proper pistons. but yes, it is doable.
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Quote Originally Posted by 82eye View Post
    The 200 head also has single valve springs and 4 cam journals vs. the 885's double springs and 7 journals. The 731 is kind of a higher performance version of the 200 head.
    I don't think the m20b25 pistons clear the 200 or 731 head. Just get an 885.
    82 320i 89 325i
    Quote Originally Posted by hotdish View Post
    The 200 head also has single valve springs and 4 cam journals vs. the 885's double springs and 7 journals. The 731 is kind of a higher performance version of the 200 head..
    all true. skipped over the rest hoping the minimal info i gave was enough to derail a bad idea..
    Aug 2016
    EastCoast
    2001 740i
    Thanks fellas the reason I asked I completely fucked up my current head I snapped the middle bolt that holds on the intake manifold to the head I then tried to drill it out and just made the hole super off centered and uneven I’m gonna try to Chisel the bottom off the intake manifold off from the head maybe with enough force it will pop off I don’t really care if the intake manifold breaks in the process. No machine shop wants to touch it lol I guess my own dumb expensive mistake IMG_0800.JPG
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    Oh dear...
    Interested in vintage cars? Ever thought about racing one?
    Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
    Elva Courier build thread here!
    Aug 2016
    EastCoast
    2001 740i
    Quote Originally Posted by ELVA164 View Post
    Oh dear...
    Lol I know I’m I can’t get upset all I can do is laugh at my dumb ass self, and bite the bullet buying a new cylinder head
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    dude, keep drilling till the head of the bolt is clear enough to slide the manifold off. then you can unscrew that broken bolt from the head and just put a new bolt in its place
    No e30s again.
    Aug 2016
    EastCoast
    2001 740i
    Quote Originally Posted by superj View Post
    Thanks for the encouragement I appreciate it I’ll give it ago tonight at this point I have nothing to lose might as well aim for the best.
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    When you get the manifold off, I would use a propane torch to get that bolt as hot as you can, then try to unscrew. Heat really helps free up frozen bolts.
    82 320i 89 325i
    agree with the above. the head is probably savable if you haven't got past the the manifold too deep. pull the manifold off and you can probably replace that stud. it's no big deal, a couple broke when i pulled my engine apart for rebuild as well.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Dremel to cut the bolt head off. Heat and a stud removal tool to get the stub out.
    "Howdy, Folks!"
  1. Replies: 0
    Last Post: 03-01-2012, 11:09 PM
  2. Difference between m52 and s52 cylinder head and can a m52 go on a s52 motor?
    By Jackpierce22 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-01-2009, 01:43 PM
  3. Difference between s50 head and s52 head
    By svp559 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-27-2006, 02:59 PM
  4. Difference between 3.0L head and 3.2L head?
    By QuestMCoupe in forum 1992 - 1999 M3 (E36)
    Last Post: 09-18-2002, 12:47 PM
  5. New amps and sub work with HK head and speakers?
    By DSK M3/4 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-04-2001, 04:19 PM
