Results 1 to 5 of 5
Thread: Performance chip problem
    Feb 2008
    Lighthouse Point FL
    M6 E24
    Hi guys, I have an early 1987 M6, and recently tried installing a Conforti/ turner, chip. When I opened my ECU part #0-261-200-079, I found that the original chip was soldered in, not in a socket. I took the ECU to my local electronics shop, and had them professionally remove the chip and install a socket. Problem is, the stock chip works perfectly, but the Conforti chip is a no start. I had Turner send me a replacement, same thing. I happened to have a Dinan chip from my old M6, and it wont start either! I'm aware of the divot, and each time I replace the stock chip it starts right up and runs perfectly! I've felt the difference on these cars and know the performance gain is substantial. Is there something different about the ECU's that had the chips soldered in? Help if you can! Dan
    Feb 2009
    Arizona
    1998 e36
    Chip is soldered in 059 ecu then you got 0 261 200 059 ECU that someone put a 0 261 200 079 lid on it.
    http://forums.pelicanparts.com/porsc...acement-2.html
    Sep 2012
    Campbell, Ca
    1985 635CSi
    The chip in my 059 ecu is not soldered and I suspect none of them came that way.
    Sunny Cali,
    6.5 second 69 Camaro
    Replace the ECU/DME and you can enjoy your Performance chip, Had to do the same, Bought a used one on Eflay. Just be sure you replace with the correct DME, 059 has 2, One is a 24 pin and the other is 28 pin.
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    The ECU 0-261-200-079 had two stock chips with the same number of pins, a 355-786 and a 355-210. Dinan makes two diff chips depending on which stock chip you had so Conforti does the same? Dinan has a 3422 and a 3421 and I can tell you they do not interchange, wrong chip=no start for same number ECU.
    Rob E3
  1. Problem with performance chips - I'm stuck
    By wokke in forum 8 Series (E31)
    Last Post: 02-08-2010, 01:02 AM
  2. performance chip/spark plug problem possible?
    By jraifaisen in forum 1992 - 1999 M3 (E36)
    Last Post: 12-04-2007, 11:32 PM
  3. TMS Performance Chip, 89-91 325i, 525i
    By timers-88-325i in forum BMW Parts For Sale
    Last Post: 08-29-2001, 05:46 PM
  4. Turner/Jim Conforti Performance Chip E36 325 1993-1995
    By Gobind in forum BMW Parts For Sale
    Last Post: 06-19-2001, 04:21 PM
  5. Jim Conforti Performance Chip for 93-94 325/525/i/is/ic/it
    By Lopaka in forum BMW Parts For Sale
    Last Post: 03-15-2001, 01:52 AM
