Page 3 of 3 FirstFirst 123
Results 51 to 56 of 56
Thread: first start turbo problems
  1. #51
    Apr 2015
    Tennessee
    1998 BMW 328i
    Quote Originally Posted by IR M5 View Post
    Btw your vacuum at idle is super low. Something isn't right.
    Thats What I'm thinking too. My idle vacuum is somewhere around 20 in/hg and his is like 8
  2. #52
    Montreal, QC Canada
    328is GT35R
    Synapse sells an adapter for the BOV that keeps it closed at idle, i got that and it helped me a little bit. more driveability wise though i was getting stuttering while driving on minimal throttle. Im regretting that BOV though i feel like it is causing other issues.
  3. #53
    Dec 2013
    Raleigh
    1993 325is
    i actually ordered that antistall kit directly from synapse, and 3 days later i got a refund so not sure if they are discontinued or not. i was able to adjust the preload spring in and remove one vacuum line from the back and now its closed at idle.
    bit of an update though, looking over my maf wiring the black wire maf side was straight up not even connected if not intermittently connected. it looked like it was in the butt connector but i was able to pull it right out. fuck. corrected that no change to anything. i can unplug it and watch the afr go from solid 8 to a fluctuating 9.5-10.5 with a hunting idle. plug it back in and it corrects back to 8. measured voltage @ maf and was getting 1.2v. technica is saying thats way too high and it should be at about .75v. so new maf on the way. hopefully that should get me closer to stoich.
  4. #54
    Jan 2016
    Littleton, Co
    E36 S52 M3/4/5 Cos. Blk.
    Maybe that maf is bad, or broken now. You ordered a new from technica? Maybe solder it this time? Really hope that is the 'simple' issue. Fingers crossed.
    '97 BMW M3/4/5, Cosmos Black.
  5. #55
    Dec 2013
    Raleigh
    1993 325is
    Replaced the maf, new plugs and shes running better than ever. spins through third. thanks for all the help guys.
  6. #56
    Sep 2013
    Roxbury, MA
    1995 M3 Turbo 1997 M3
    This ^^^ vacuum reading is certainly the route. On start up it should be lowest 15 and will increase numerically I have the same HG setup and noticed no change. Average 20 at operating temp. The rich afr throws me off but the is a large vacuum leak somewhere, also has to do with pressure releasing so fast on the boost test.
    1995 M3 Alpine on Dove
    AA Turbo manifold HX40 T3 CES 3" Piping Mishimoto R Line intercooler Turbosmart Ultragate & Raceport BOV CES Cutring 115# RK Tune E85 Aeromotive FPR Walboro 485 DKM Twin Disc Innovate SCG-1 & ECB-1 Porsche BBK FitmentLab Overfenders Hamann PG1's
    1997 M3 Estoril on Rain
    AC Schnitzer Type 1's Bilstein PSS9's Turner: Monoball camber plates, rear camber arms, front & rear sway bars w/ reinforcements Supersprint Long Tubes
    AP Racing BBK
  1. 316 se xreg problems on first start
    By steph290504 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-23-2013, 12:02 PM
  2. Strange Problem-Traction control, Hand brake light yellow only when I first start
    By vitaladeel in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-21-2013, 04:15 PM
  3. E36 M3 Turbo: First Start, Blown Headgasket
    By jake06 in forum Forced Induction
    Last Post: 08-27-2013, 08:57 AM
  4. First Cold Starts - New Problems
    By AshamedGorilla in forum 1991 - 1999 (E36)
    Last Post: 12-06-2009, 05:26 PM
  5. BMW E32 735i Turbo - First Start - m30 w/ 745i parts
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 07-30-2008, 08:19 AM
