Results 1 to 2 of 2
Thread: Turner F80 M3/M4 Performance Tuning Module
    Mar 2005
    PA
    BMW
    Product Details
    PLUG IN AND PLAY WITH POWER!
    Max HP gain = 60 hp
    Max Trq gain = 75 ft-lbs
    Plug And Play Engine Harness!
    More Boost With Factory Driveability!
    This Performance Module is a direct plug in to the existing engine harness for a factory appearance and fitment and an instant 60hp gain @ 6650 RPM and 75ft-lbs of torque at 6500 RPM. These are simply amazing gains! It installs in approximately one hour and is completely reversible which makes this the easiest and most effective power upgrade you will ever make on this car. If you're looking for a substantial bump in power output, with minimal downtime for installation, full serviceability, and can be reverted back to stock then the Turner power upgrade is unbeatable!
    Turner's M3/M4 upgrade solution is a tuning module that plugs in ahead of the engine computer on the wiring harness. It's not the run-of-the-mill 'piggy-back' style upgrades you find for less. Inside our module is a sophisticated control unit that is designed to complement and work with the factory ECUs. The maps and algorithms within the control unit have been optimized for the S55 engine, sending revised fuel and ignition parameters to the stock ECUs to control boost depending on load, engine speed, and other factors. Our control unit integrates seamlessly to extract more power and torque without faults and errors - just smooth power and torque. The harness has factory-style weather-proof plugs to connect in-line with each boost pressure sensor and the camshaft position sensor on the engine.
    All of the factory safeguards remain in place, including overload protection and warm-up protocols to preserve longevity and factory drive-ability. One of the key advantages of this type of system is that it is unaffected by factory BMW updates and service. If BMW updates the computer software to fix any small bugs or issues, the Turner performance upgrade is not lost or overwritten. This is key on new models because BMW is constantly releasing small software updates. All of the factory diagnostics and service access is retained. The Turner Module is undetectable to plug-in diagnostic readers and it leaves no traces behind. A valet connector is included and installs in minutes to bypass the performance module and revert the car to factory settings. With the valet plug installed the engine computer will use the stock maps instead of getting modified data from the Turner module.
    Click here for installation instructions.
    This item fits the following BMWs:
    2015+ F80 BMW M3
    2015+ F82 BMW M4
    https://www.turnermotorsport.com/p-3...module/?pdk=Aw
    $475.00 shipped (continental US)
    Mar 2005
    PA
    BMW
    $300 shipped
  1. F8x ///M3 + ///M4 Performance Brake Calipers. (NOT CERAMIC)
    By puredriving in forum Brake Kits, Rotors & Pads
    Last Post: 11-02-2017, 12:56 PM
  2. F80 M3 Akrapovic Delete-R Module
    By c2wak in forum Engines, Performance Parts & Software
    Last Post: 07-15-2017, 11:48 AM
  3. Turner Performance Tuning Module now available at ECS Tuning
    By ECSTuning in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 05-03-2017, 05:31 PM
  4. OEM EDC Suspension H&R lowering springs F82 F80 M3 M4 - No Longer Available
    By eddie36 in forum Suspensions, Springs & Shocks
    Last Post: 05-14-2016, 04:15 AM
  5. F80 M3/M4 Austin Yellow Metallic on E36 M3?
    By rajicase in forum 1992 - 1999 M3 (E36)
    Last Post: 10-26-2015, 12:24 PM
