Results 1 to 9 of 9
Thread: Car paint restore-able?
    Apr 2018
    Indiana
    Mk1 VW Cabriolet
    Hello,
    I am currently in the market for an E30, and I think I found pretty solid car. The only thing wrong with the car is that the paint is fading a bit. As I haven't buffed or waxed a car before, is this paint still in good enough shape to make it look good again?
    Thanks,
    Roman
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    The thing that typically goes on the paint is the clear coat peeling off. There's not much you can do with that along the lines of buff or polish.
    "Howdy, Folks!"
    Nov 2005
    canada
    2001 740i
    If it's single stage it's restorable as long as it's not too far gone. If it's base clear and peeling or faded then you are SOL. Here is a restored/unrestored comparison of my 318. The whole car was pink like the right side of the hood. This is single stage paint.
    1991 318is
    2001 740i
    Valencia, CA
    Imola E36 M3 E30 Touring
    If it's a non-metallic color, and it's original paint, it will be a single stage paint job. No E30 factory paint job had clear coats, except metallic colors.
    Single stages can be polished back to a nice shine, until you run out of material.
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Quote Originally Posted by earthwormjim View Post
    Can confirm. I've accidentally gotten to primer on a late zinno bumper before. If the car has never been buffed before you should be able to get it looking potentially better than new.
    Apr 2018
    Indiana
    Mk1 VW Cabriolet
    This is the current condition of the paint.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    you can do that one. it might not be perfect but it will be way better
    No e30s again.
    Apr 2015
    Toronto
    e30s
    it looks to be original and probaby hasn't been poilished before. Typically when this happens the sides of the car don't get the direct UV exposure so it stays much shinier. But if it's a repaint in some areas like the sides you're still ok. There is a way to check how much paint you have using a guage (mm's) if you are ok with getting a pretty decent shine you don't need much with single stage. If you want an exceptional finish it's recommended you water sand the surface and then polish. But I'd suggest that someone with experience/professional do that if you aren't so inclined. The safest polisher out there is a Duel action (DA) which won't risk you burning through the paint and you will get a very nice finish overall. Key is to have professional grade polish/product for the best results.
    Apr 2018
    Indiana
    Mk1 VW Cabriolet
    Ok, thank you for all the advice!!!
  1. RIXCAR | car painting and restoration workshop | exhaust tuning
    By Rixcar in forum Vendor Comments & Supporting Vendor Info
    Last Post: 09-29-2014, 01:11 AM
  2. car paint question.....
    By dieselm3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-12-2003, 03:52 PM
  3. HELP!!! CAR Paint thinning!<@
    By MaloventEvil in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 05-09-2003, 06:56 AM
  4. Finally getting my car Painted!! Have some ?s
    By scottycs in forum 1992 - 1999 M3 (E36)
    Last Post: 04-15-2003, 09:19 AM
  5. You think your cars paint is smooth? Take the test...
    By Hyperion in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 05-14-2002, 01:30 PM
