Results 1 to 5 of 5
Thread: BMW S54 Misc Parts - $200 package deal for a ton of stuff.
    Jan 2005
    Wichita, KS
    2011 E90 M3, 2004 M3
    BMW S54 Engine Parts
    Here is what I have leftover from parting out 3 motors and keeping part of 1. This is most of what you need that attaches to a long block. I’ve priced parts accordingly so you could build an S54 cheaper than buying in pieces than buying a used motor.
    Let me know if you have any questions.
    Paypal is breakmywallet@outlook.com
    Cylinder head parts
    2x set follower rods - $30
    1x valve cover (hot tanked and clean) - $125
    1x timing chain tensioner - $50
    1x set timing chain sprockets - $40
    1x fuel rail - $20
    1x intake cam sensor - $20
    1x PCV - $15
    Bottom End
    5x oil squirters - $510
    3x oil pump bolts - $10
    1x plastic timing chain guide - $10
    2x rear main seal housings - $10
    3x front timing chain covers - $20
    1x OE clutch disc - $10
    1x crank position sensor - $20
    1x pr front O2 sensors - $30
    2x set of 3 knock sensors - $50
    Accessories
    1x left SMG engine mount brackets - $25
    1x left 6MT engine mount brackets - $25
    1x AC compressor bracket w/ belt tensioner - $25
    1x power steering reservoir bracket - $10
    1x VANOS pressure accumulator - $30
    1x VANOS sealing plate - $20
    1x water pump pulley - $5
    2x idler pulleys (go on end of upper alternator bolt) - $10
    1x oil line from PCV to oil pan - $10 (pre-2003/non-AN fitting end and needs rubber hose replaced)
    1x fuel/vacuum line to FPR - $10
    1x OE fan blades - $10
    2011 E90 ///M3 Individual
    2004 ///M3 - Track Car
    Jan 2005
    Wichita, KS
    ttt
    Jan 2005
    Wichita, KS
    ttt
    May 2012
    Washington DC
    2004 M3
    Sent PM
    Jan 2005
    Wichita, KS
    ttt
  1. Replies: 4
    Last Post: 05-15-2016, 04:13 PM
  2. Replies: 0
    Last Post: 08-19-2013, 02:13 PM
  3. Replies: 10
    Last Post: 12-08-2010, 01:03 PM
  4. Package deal for 95 M3 1/95 +
    By chas in forum BMW Parts For Sale
    Last Post: 10-11-2006, 08:32 AM
  5. BMW E36 Misc Parts
    By MPRESION in forum BMW Parts For Sale
    Last Post: 02-28-2003, 11:12 PM
