Results 1 to 6 of 6
Thread: E39 530I differential
    Apr 2018
    Placerville
    E39 530i
    I have a 01 e39 530i And the diff blew up and I got a new diff but where the drive shaft connects to the diff it’s still 6 bolts but the bolt pattern on my drive shaft is bigger than the new diff where it connects what diff do I need to get ?
    Mar 2017
    Adelanto California
    2000 BMW 528i
    Quote Originally Posted by Brendankulp View Post
    Do you have a bentley manual? I lost mine otherwise I'd pull up pictures. I belive the part you are talking about is apart of the CV (Constant velocity joint) which connects to final drive. To my knowledge all I6 e39 motors were equiped with compatible driveshaft. Where did you get you this replacement differential? Have you done your homework as to what is actually compatible with your car?
    Sent from my SM-G955U using Tapatalk
    San Jose, CA
    1997 BMW 540i 6 speed
    Check here for part numbers: www.realoem.com
    Baltimore, MD
    Blown 530
    yep, probably wrong diff. All six speed diffs are interchangeable. I've done 3.46, 3.64 and 4.10
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Yep. What he said. Bought the wrong diff.
    I think someplace there's an updated version of this table that lists more E39 models. There's more weirdo stuff than you would think.
    https://www.bimmerforums.com/forum/s...9#post29155829
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    OP, not sure where you're located, but I have two 3.46 525it/530i automatic diffs that have the correct size flange. I'm in Charlotte, NC. If you're somewhat nearby, let me know if you need one of them.
    ***EDIT***, I think I misread your post. Sounds like you might have the manual 530i with the larger flange requirement and you bought an auto diff. If this is the case, disregard my offer as it will only put you in the same situation. I do however think I still have my 528it manual diff, which I think has the larger flange, but it's 2.93 ratio, so not sure it's worth anything to you or not.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  1. 2002 E39 530i auto differential question
    By Cholupa in forum 1996 - 2003 (E39)
    Last Post: 12-29-2013, 04:12 PM
  2. E39 ESS Supercharger BMW E39 530i 530, E46 330i 330, Z4 M54
    By rpg in forum Engines, Performance Parts & Software
    Last Post: 06-14-2011, 03:49 PM
  3. E39 e39 530i Parts for sale! everything must go!
    By beatbangerz in forum Whole Parts Cars
    Last Post: 07-22-2008, 08:26 PM
  4. E39 e39 530i Muffler
    By KOLYAtheDJ in forum Engines, Performance Parts & Software
    Last Post: 03-05-2008, 03:38 PM
  5. E39 MID head unit (non DSP) from 2003 E39 530i
    By sidneyj in forum Car Audio & Electronics
    Last Post: 07-13-2007, 06:40 PM
