Results 1 to 17 of 17
Thread: Exploding fan!!!!
    Apr 2015
    Gulf Coast Fl
    98 M3
    Exploding fan!!!!
    Title says it all. I replaced the whole cooling system 3.5 years ago and now square one. destroyed my nice aluminum radiator too
    Aug 2009
    sunnyvale CA
    325is
    Mine looked like it exploded too. The water pump bearing went out and the fan blades hit the radiator, fan parts everywhere!. The pump was not leaking but you could see things wobble while running. I thought BMW fixed the problem with a new pump design....
    Dec 2014
    Alexandria, Va
    1996 328is, 2003 325ci
    Maybe with high temps you see in Florida and maybe some high RPM runs your fan gets a workout. Check it regularly for cracks. Sorry man it sucks.
    Apr 2015
    Gulf Coast Fl
    98 M3
    Yeah it does oh well....going to replace everything and motor mounts just incase.
    washington dc
    Avus Cosmos Calypso!
    Replace your motors mounts. Bad ones almost guarantee exploding fans.
    Nov 2007
    Central IL
    E36
    I went to the diesel fan, it has an outer ring that is fairly stiff and, in my mind, could help not exploding. It does seem to have less chord angle and fewer blades, so may not push as much air, but I'm in IL, and don't need as much as FL maybe.
    11522243303
    https://www.ecstuning.com/b-genuine-...522243303~geb/
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
    Apr 2015
    Gulf Coast Fl
    98 M3
    Water pump is done! I can move it up and down thinking it was the cause of the exploding fan.
    Sep 2017
    PA
    1996 BMW 328i Sport
    I had that fan destroy itself about 3 times. The last time it also took out a good couple chunks of my radiator and some hoses too. This was after I did the cooling overhaul too. I just did the fan delete mod and replaced the clutch fan with an electric fan attached to the radiator. The car felt smoother during acceleration and also I don't have to worry about the fan exploding anymore �� look into the fan delete mod, it's worth it imo
    Apr 2015
    Gulf Coast Fl
    98 M3
    Quote Originally Posted by ilyasoul View Post
    what parts did you use
    Oct 2012
    Detroit, MI
    E36, E70, i3
    That shouldn't happen.
    Your motor mounts are probably jacked. Engine is tilting back and forth as you accel/brake and fan is contacting the shroud. The mechanical set-up has been fine on thousands of maintained E36s for over two decades.
    Sep 2017
    PA
    1996 BMW 328i Sport
    I used a 16 inch electric fan mounted to the radiator. I installed a sensor within the coolant lines, so the electric fan would turn on at certain temperatures. Also, I installed a lower temperature thermostat to help with the cooling. The radiator was hooked up with a wiring harness to the junction box in the engine bay to receive power for the fan. Some people also use redline water wetter as an additive to their coolant to help with temperatures.
    Quote Originally Posted by Nanniepoo View Post
    Yeah I changed the motor mounts after it blew up twice, but then it still cracked on the 3rd time, and I just decided to an electric fan conversion
    Mar 2001
    houston
    '94 325i,'08 civic
    radiator mounts
    and do not forget the 2 radiator rubber mounts for proper spacing.
    Oct 2013
    Australia
    Nil BMWs as of 2020
    Quote Originally Posted by Moron95M3 View Post
    11522243303
    I'd say it probably wouldn't suit for warmer parts of the USA. E36s offered in areas such as Japan and Australia (whose climate really wouldn't be dissimilar to many parts of the USA) were fitted with the "Hot Climate" fan clutches and fan blades that give more cooling ability much sooner. The fan in my little 320i doesn't need much persuasion to sound similar to a jet engine!
    https://www.bimmerforums.com/forum/s...and-Fan-Blades
    Reading my old thread there, the diesel fan blades (and water pump) were mated with a pulley that was smaller in order to drive them faster.
    For those complaining about "exploding fans," it is a symptom of another problem. Engine mounts are often the culprit. A failing water pump (i.e. bad bearings) is another cause. While I understand there can be failures without warning; these underlying issues point to ignorance (maybe that's why my Diff is sounding sickly )... If the water pump has that much slop in it, it should be noticeable to the naked eye when you inspect your engine. When you replace your serpentine belt, that is the perfect time to check your pulleys and water pump for noise/slop. Likewise with mounts, it'd be pretty visible if the engine was moving around so much.
    The OE cooling system has been more than adequate. Fan Delete Mods seem to require investment in high performance water pumps, colder thermostats, coolant additives and colder fan switches. All this points to it being inadequate. Meanwhile, when your fan clutch locks up, even revving the engine at 1000rpm will move significantly more air. At 2000-3000rpm with the fan roaring - well, no electric fan can do that.
    Aug 2009
    NW Indiana, USA
    '94 325i Sedan
    11522243303
    Which fan clutch did you end up using? Did you use your original gas motor fan clutch ( 11527505302 ) with the diesel fan, or did you have to buy the diesel fan clutch ( 11522246042 )?
    Looking at the RealOEM pages, I see that the 325td fan clutch has a different part number than the gas engine fan clutch. Because diesels run at lower RPM I'm wondering if the choice of a clutch is significant when putting the diesel fan on a gas motor.
    How long have you had this setup on your car?
    (oOO \ (||||)(||||) / OOo)
    Oct 2013
    Australia
    Nil BMWs as of 2020
    Quote Originally Posted by pescadero View Post
    In my response above, I linked this thread here: https://www.bimmerforums.com/forum/s...and-Fan-Blades , a discussion on the "Tropical/Hot-Climate" fan clutch and fan blades the petrol (gas) E36s could be fitted with. Of interest is the fact the diesels do have smaller pulleys to ensure the fan is driven fast enough given the lower rpm of a diesel engine.
    You'll need to double-check the parts diagrams as I do believe some clutches will only mate with some fans (three screws vs four, diameter and so on).
    Aug 2009
    NW Indiana, USA
    '94 325i Sedan
    thanks for posting. I noticed that thread, and that the most important data was conspicuously absent. Although people have discussed the fan blade pitch and the pulley size, what's missing is the temperature on/off specification for the clutches. is that information available anywhere?
    Oct 2013
    Australia
    Nil BMWs as of 2020
    Fan clutch manufacturers could possibly have that information. All I can tell you, based on owning/driving an E36 with the "hot climate" fan clutch is it is generally quite aggressive at locking up and the fan 'roaring' in warmer/hot weather conditions (although when it was brand-new, it was reluctant to lockup with the A/C & auxiliary fan running on low, resulting in the aux fan running on high. If the A/C was switched off, the fan would lockup normally!).
  1. Question about weak motor mounts/ and exploding fan.
    By Motorsport333 in forum BMW Rides & Events
    Last Post: 04-26-2008, 09:01 PM
  2. exploding fan!
    By HomerJ64 in forum 1991 - 1999 (E36)
    Last Post: 09-11-2007, 02:15 AM
  3. Exploding fan/fan clutch - how common?
    By kmetros in forum 1995 - 2001 (E38)
    Last Post: 10-27-2006, 01:57 AM
  4. Exploding Fan Theory?
    By LegalMaven in forum 1995 - 2001 (E38)
    Last Post: 05-01-2006, 07:59 PM
  5. Caution.. Exploding fan of death!
    By BMuu in forum 1991 - 1999 (E36)
    Last Post: 01-30-2006, 06:19 PM
