Results 1 to 5 of 5
Thread: Rough Idle/Check Engine Light - solved
    Apr 2017
    San Diego, CA
    90' 735iL, 90' 535i, 93'
    Lately I've been having issues with rough idling and a check engine light. The rough idle also changes the exhaust odor and sapps my mpg. Cleaning and swapping used Idle Air Control Valves will temporarily resolve the issue but it's back within a couple weeks. Stomp test gave me code 1222 Lamda (o2) sensor.
    Is there a way to test wether the o2 sensor or the IACV is throwing the CEL? Could a bad IACV cause the O2 sensor to have issues or vice versa?
    Any input on this situation would be greatly appreciated!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    O2 sensor can be tested with a voltmeter, see shop manual https://www.bmwtechinfo.com/repair/main/481en/index.htm
    https://www.bmwtechinfo.com/repair/m...es/4810056.jpg
    Pull the fuel pressure regulator vacuum hose and check if there are gasoline drops inside, then the diaphragm inside is borken
    Apr 2017
    San Diego, CA
    Thanks shogun, I will give that fuel pressure regulator a look, it's been replaced recently but it's not any trouble to check.
    I'm sure I can hunt down the plug for for that O2 sensor by tracing the cable back from the cat region. But if anyone knows exactly where it is off hand I'd greatly appreciate the protip
    Jan 2005
    Japan
    You can test the O2 sensor also another, easier way, from the top of the motronic.
    Here I made a write up http://www.bimmerboard.com/forums/posts/622383/
    unfortunately the imageshack pics do not work anymore nowadays. You have to remove the top cover of the connector on the Motronic that you have access to the pins from top
    Here a pic I made from a Motronik M1.7 with Bosch end # 352 for the M70, so you get an idea http://www.bilder-upload.eu/show.php...1524115135.jpg
    hope one of the 2 links works, same pic
    Download the pic to your PC!. That free upload server kicks the pic out and deletes it after 200 days.
    Apr 2017
    San Diego, CA
    Wanted to update and put this thread to bed!
    O2 sensor was long done.
    Had to drop part of the exhaust to make enough space to loosen the sensor.
    I'd read in another write up about a $16 O2 sensor removal tool... BUY IT! Unless you have a lift and very tiny hands life is going to be rough.
    By the time I realized how invaluable that tool was I'd already cut the sensor wire in an attempt to slip a wrench over it.
    I was lucky enough to have a box end wrench that was able to get the job done (with plenty of struggling still).
    Drove one way with the new sensor in, no issues but on my way back home all previous symptoms had returned.
    As a last ditch effort I threw my original idle air control valve back in and thankfully all problems have been solved! Turns out I had a bad o2 sensor and IACV everything is working amazing now.
    Even though I really didn't want to drop the exhaust, when I did a huge rock fell out from somewhere underneath the vehicle. Turns out the rock had been causing an intermittent and mysterious rattle while reversing or accelerating from a standstill. And I'd been thinking it was a noisy driveshaft u-joint....
    Much appreciated for all this assistance as always!
  1. E34 540i Rough Idle Check Engine Light
    By e34lives in forum 1988 - 1996 (E34)
    Last Post: 03-19-2018, 10:27 AM
  2. E36 rough idle + check engine light issue
    By Gokartish1 in forum 1991 - 1999 (E36)
    Last Post: 03-31-2017, 05:43 PM
  3. bmw 1994 540i rough idle, check engine light
    By dallas1993 in forum 1988 - 1996 (E34)
    Last Post: 07-01-2010, 12:46 AM
  4. M60 sporadic rough idle/check engine light
    By Jcbe34 in forum 1988 - 1996 (E34)
    Last Post: 06-03-2009, 06:39 PM
  5. 94 540IA rough idle; check engine light on.
    By bahnburna in forum Great Lakes - US
    Last Post: 08-27-2007, 10:42 AM
