Results 1 to 3 of 3
Thread: E30 updates and questions
    Nov 2011
    mcallen TX
    2003 BMW 325ci
    Updates on the 1987 325I: I got the car running. When it’s cold it’s stumbles a little but once it warms up it revs nicely but when it comes down to idle it takes a moment or two to idle smoothly. At idle it’s stumbles a little but very subtly. Don’t know if this old of a computer has a learning capability or if this is purely a tuning or adjustment issue. Also want to see if there are any vacuum leaks by using some propane through a tube and run it around the hoses and gaskets. Still have some wires that I don’t know where they plug into or if they were plugged in at all. I attached a picture with the wires so any input would be greatly appreciated. Also my speedo still dosent work so any input would be appreciated (I put new plastic gears in the speedometer), Also how to you test the sensor in the diff(I removed it and cleaned it but that didn't seem to work
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I think one of those wires plugs into the back of the obc and the other end plugs in to something by the ecu. but, its been many many years so hopefully someone can verify
    No e30s again.
    Apr 2015
    Toronto
    e30s
    the stumbling during cold is normal but when it's warm it could be vacuum and it could be a dirty ICV. Clean out the ICV and see if that changes the issue.
  1. Synn's Silberkrugel update and questions thread :shifty
    By Synn88 in forum 1999 - 2006 (E46)
    Last Post: 12-11-2010, 06:52 PM
  2. Update and Question -- Starter Motor
    By jonno318i in forum 1999 - 2006 (E46)
    Last Post: 07-24-2009, 04:47 PM
  3. E30 decisions and questions
    By uribendovid in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-07-2007, 07:05 PM
  4. New/First E30. Pictures and questions.
    By kage2021 in forum 1983 - 1991 (E30)
    Last Post: 08-18-2006, 10:49 PM
