RM European Auto Parts
Results 1 to 6 of 6
Thread: Engine swap or fix question
    Nov 2017
    Phoenix
    2001 330Ci 2012 X5 3.5
    I have a 2001 330Ci 5 speed with about 165000 miles on it. The oil pan is leaking and last year cylinder 1 spit out the spark plug taking the coil pack with it. Not really sure why that happened. A buddy of mine reset the spark plug using a heli coil and its been running beautifully ever since. (Dear god I love this car) My concern is that it will eventually spit that plug out again tho.
    Should I do repairs on this engine or just swap in a new (used) one?
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    I had the same issue with my old M52TUB25 (previous owner had put a 4cyl dipstick and it messed up the reading, the chain tensioner did not appreciate after some hard mountain drive, that's a long story...) and the helicoil did just fine. Although I'm not sure it was repaired the same way yours was (a turner created a new threading in the engine block after soldering an aluminium cylinder into the plug's housing).
    It actually survived an engine blow-up...so I wouldn't worry too much if I were you, or just wait until it actually spits it out.
    Quote Originally Posted by GriffX5 View Post
    If the repair was done properly, it wouldn't even be a concern of mine.
    Nov 2017
    Phoenix
    Really? That's good to hear. I have faith in the mechanic who did I just had heard inline threads are timebombs. If that's not the case then I'll just fix the oil leak and keep the motor i got.
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    My former engine was not in the best condition and maybe compressions were a bit lower than they should have been, which could (?) explain why the thread held, but I doubt that.
    If you wanna be on the safe side you can take the spark plug out in a few hundred miles/months (always on a cold engine and never tighten it back too firmly) and check it out, but your engine should be fine. Mine held on for a good 3 years after the issue even with hard driving/redlining, you name it...
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Griff, I agree fully with White94RX. Don't worry about it....fix what's actually broken.
    Chris Powell
    BMWCCA 274412
  1. Broken Rocker Arm... engine swap or just fix it?
    By colinE30 in forum 1983 - 1991 (E30)
    Last Post: 02-25-2011, 07:08 PM
  2. e36 into e30 engine swap or 4cly turbo questions.
    By Cosmos///95Lux in forum 1987 - 1991 M3 (E30)
    Last Post: 09-16-2010, 01:56 AM
  3. M3 engine swap or new car?
    By sbc325 in forum 1991 - 1999 (E36)
    Last Post: 04-17-2004, 08:35 PM
  4. Engine Swaps Or Turbo 318is E36
    By MARUS in forum 1991 - 1999 (E36)
    Last Post: 03-07-2004, 04:12 PM
  5. Engine swap or new car
    By lasd in forum 1991 - 1999 (E36)
    Last Post: 12-24-2002, 12:15 PM
