My apologies for posting this question here. I try different sites not able to locate starter relay. Can you please assist me. Thanks, in advance.
this is the 3 series section but if you know the part number, you can search it in google to locate someone selling it. if you don't use realoem.com and input the year and other little things it asks about and you can get the part number from there
No e30s again.
THANKS for your response! This is the issue with 1998 528i, there is no power to starter, I can by pass it via starter. I need to access it to the ignition. Let me thank you in advance for your response.
I searched and i think your relay is located behind glowebox.There should be a few relays there.The starter relay K6324 should be little green box on the left side of the fixture.
BIG THANKS! I will try it by the weekend. Ed
