Hey guys, I'm planning on installing raceland coilovers onto my '92 318is. I'm stressing over the possibility that I may need spacers. I'm definitely going to get my fenders rolled. I'm running 18 inch wheels with slightly stretched tires. It would be a huge help if anyone has had a similar setup and whether they needed spacers or not.
This is my wheel setup:
Front: 18x8.5 +38 215/40R18
Rear: 18x9.5 +35, 225/40ZR18
Thanks guys!
I would be stressing about the Raceland coilovers much more than the spacers...
12mm front spacers would work. Less would probably work but you need a hub.
No. 12” and up you just need spacers and longer bolts. 5mm works with stock bolts. Don’t get 10s then you’ll need hub extender and bolts.
