Results 1 to 3 of 3
Thread: coilovers vs. standard spring/strut combo
    Apr 2018
    Vallejo, Ca. 94591 U.S.A.
    1997 BMW e38 740 iL
    ive got a 97 e38 and need suspension, and it seems coilovers and factory replacement struts and springs are really close in price. and not knowing these cars well enough to know which is going to be better for good handling and smooth ride. i like how my car sits so lowering isnt my goal, mabey an inch or so at the most. also if anyone has recommendations on brand/model for either, or on suspension kits, front and rear, id appreciate it, because its hard to tell whats good and whats not. thanks in advance to everyone.
    Aug 2013
    1999 BMW M3 Coupe
    If you want any ride height change at all, you need aftermarket coilovers, either with height adjusters front and rear or with springs that lower it a fixed amount and aren't adjustable. If you don't care about changing ride height I'd encourage you to get OEM replacements for your worn out shocks and call it good. If you want to look at aftermarket brands, some to consider are Bilstein, H&R, Koni, and Ground Control (who also uses Koni).
    Mar 2003
    somers,ny
    u dont need coilovers......
    buying stock stuff is fine , but if u want to go a bit lower consider HR or eibach spring set w/ a nice shock like koni or bilstein, even sachs
    TCK or Dinan may have a non coilover spring set for you, I doubt GC sells a non coilover sprg set 4 u.
    alpina or hartge may even have a nice kit for you
    try your specific car forum here
  1. Coilovers>> Spring/strut combo?
    By Vazquezp in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-13-2013, 06:33 PM
  2. KW coilovers vs. Koni/spring combo for plush ride in E34?
    By mint e34 in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 02-06-2013, 08:48 AM
  3. Feeler: Trade DDM coilover for spring/strut combo
    By XPME36M3 in forum California sponsored by Avus Autosport
    Last Post: 12-12-2009, 12:55 PM
  4. coilover vs H&R/Bilstein combo
    By Matt_337 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-23-2003, 05:16 PM
  5. Best Value Springs/Struts Combo to drop 2"
    By poynter in forum 1991 - 1999 (E36)
    Last Post: 12-19-2003, 09:04 PM
