Results 1 to 10 of 10
Thread: Beautiful day cruising with 2003 Z4 M/T and this happened (---HELP---)
    Feb 2016
    DE
    2003 BMW Z4 2.5i
    Cruising 60-65 miles per hour so, all of a sudden car acted like no gas, like i'm not pushing on gas and gradually started slowing down (it;s a manual transmission, i drove all my life) and pushing some gas engine acted like maybe dirt or something in the gas, pushing gas pedal created some gas through but you could tell that gas is not there or at least not enough.[/FONT][/COLOR]
    Pulled it over, waited 5 minutes looked around the engine and nothing was unusual, started the car again and wow seems like everything was back to normal, 1-2-3-4-5 gear doing 50-60 mph again like nothing happened and two minutes later same thing, like gas is not coming and car stalls if you take it of the gear. Parked the car at one of the car dealership parking lot and took a taxi to come home.
    My eyes were on the temperature gauge just in case but everything was normal there.
    Is it a fuel pump maybe? But cooling of 5 minutes everything goes back to normal for another few minutes after, doesn't sound like a fuel pump (or does it).
    Waiting Monday morning to talk to my mechanic but trying to find out as much as i can.
    Anyone experienced something like this?
    Feb 2016
    DE
    2003 BMW Z4 2.5i
    Okay guys, this morning went back to pick the car up or at least try to see what happens.
    Started the car and drove home (14 miles) without any issues like nothing happened yesterday.
    I read somewhere that fuel pump when gets hot or is not working as suppose to can cause what i went through yesterday.
    If that is the issue how can we make sure and if it’s a fuel pump what should I change, complete fuel pump or some parts of it and lastly where should i get one and cost should be?
    I would look at the fuel filter first
    PRICE CUT on ALL FABRICS
    Feb 2016
    DE
    2003 BMW Z4 2.5i
    I have been reading about all these throughout forums, fuel filter almost unlimited time frame can be good and if you have to replace it replace the fuel pump with it anyway because where it is and labor. Now i read that might be some bad gas possibilities. Always put a super but here gas has 10% ethanol in it.
    Is there a way mechanic can pin point this problem because like i said i picked the car up this morning and drove home without any problems.
    wow thats a stupid design, why would BMW go to an integrated design. E36's and Z3's had the pump in the tank, and a filter under the car. Took me literally 10 minutes to replace the one on my E36 the other day, from grabbing the jack to dropping the car... 10 minutes... on a Z4 it looks like an all day job... wow what a piss poor design choice, just like the convertible top motor location...
    It sounds like a fuel filter issue to me. Almost any other type of problem will throw a code (too much air, too little air, timing is wrong, combustion was too efficient, or combustion was too inefficient, ANYTHING other system in the car CAN potentially throw a code) but there isnt a "fuel filter" CEL or low fuel pressure light. 10% ethanol is fine, I just think its an old filter... just my .02
    Feb 2016
    DE
    2003 BMW Z4 2.5i
    Thanks, i got all the possibilities i think and my mechanic will check it out Wednesday. Without a code or repeating problem I don’t know how much more he can tell
    Dec 2013
    Chicagoland area
    EXOTICS
    Connect a fuel pressure gauge to the fuel rail,
    compare readings when engine accelerates normally,
    to readings when symptoms appear.
    Feb 2016
    DE
    2003 BMW Z4 2.5i
    I have been driving the car and that problem never repeated
    Feb 2016
    DE
    2003 BMW Z4 2.5i
    Quote Originally Posted by BimmerBreaker View Post
    I have been driving this almost daily lately and that problem never happened again not even a tiny sign whatsoever.
    Maybe it was a bad gas or something passed?
    I started hearing chirping sound with rpm goes up (at the beginning going up and goes away, by the way this has nothing to do with gas problem i had) first of i thought it was a belt like lose belt or something but mechanic listened to it and thinking maybe some air coming in with rpm rises
    Jul 2018
    Colorado
    2004 330XI, 2007 M-Rdstr
    Fuel pump? My 330xi fuel pump took a LONG time to die. Intermittent forever, then nothing. 1/2 hour to change it
  1. BIG trouble with 2003 Z4 HELP!!!
    By Salacak in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 11-28-2017, 08:49 PM
  2. Newbie here with 2003 Z4
    By BCFBasil in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 12-31-2013, 04:24 PM
  3. For sale:2003 z4 steering wheel and tan shift knob
    By darkbb4 in forum Interior Lighting & Body Parts
    Last Post: 04-23-2011, 10:11 PM
  4. What rims came with 2003 330i w/Sport and Premium Package?
    By Phobos794 in forum 1999 - 2006 (E46)
    Last Post: 05-27-2008, 11:02 AM
  5. Anyone with an AA Gen III have this happen?
    By EvilOne in forum 1992 - 1999 M3 (E36)
    Last Post: 02-07-2007, 08:42 PM
