Results 1 to 5 of 5
Thread: M70 Crank/Cam Position Help!
    Feb 2015
    Kuna, Idaho
    Too Many Cars (NOT!)
    1991 850i CB73309
    Can someone verify which wires feed the crank and cam position sensor plugs.
    Note:right and left is from inside car facing forward.
    My car has 4 wires coming out of the plastic box under the engine cover that are for these sensors.
    The top left wire has a black socket that (I belive) goes to the crank sensor and the lower left wire has a tan connector on it.
    Do those go to the crank/cam position sensors on the left side of the engine?
    Do the two wires that sit on the right side of that box go to the right sensors?
    I'm asking because there seems to other things that cross sides and I would really like to get this car running again.
    Thank you
    Mike Drives:
    BMW's
    E24 - 635CSiA - (1) 1985 (US)
    E24 - 635CSi - (1) 1985 (EC)
    E31 - 850iA - (1) 1991
    E32 - 740iA - (1) 1994
    E32 - 750iA - (1) 1990 (Not an "L") (EC)
    E34 - 540iA - (1) 1994
    E38 - 740iLA - (2) 1997 & 1998
    E38 - 750iLA - (1) 1998
    E39 - 528iA - (3) 1997, & (2) 2000
    Also:
    2015 Ram 3500 Dually
    2014 Dodge Dart
    2002 Mercedes Benz SL500
    1967 Buick Riviera
    Dec 2013
    San Antonio
    850i, '76 2002, '76 530
    I installed new crank and cam sensors in my '91 recently. Let me double-check. The right bank, 1-6 CIS (cam) goes to bottom plug receptacle on passenger side. The receptacle on top is for the top crank sensor. The top receptacle on driver's side is for the 7-12 CIS and receptacle below it is for the lower crank sensor.
    Feb 2015
    Kuna, Idaho
    Just to be sure also, the tan connectors are for the donuts, correct?
    Mike Drives:
    BMW's
    Also:
    2014 Dodge Dart
    1967 Buick Riviera
    Jul 2017
    toronto, ontario
    1991 BMW 850i
    Quote Originally Posted by masbury View Post
    I don't think so. The tan engine harness connectors are on the bottom and as JDP530 states only the passenger side tan connector is for a donut (1-6). The 7-12 donut connects to the drivers side, upper, black connector. Definitely not intuitive, probably why so many people get this wrong.
    Feb 2015
    Kuna, Idaho
    There is a top end rebuild (M70) document floating around where the author says the tan connectors are for the donuts. Weird that BMW switched colors in mid stream so to speak.
    Thanks for the correction.
    Mike Drives:
    BMW's
    Also:
    2014 Dodge Dart
    1967 Buick Riviera
  1. Cam Position Sensor Help
    By Harry24 in forum 1991 - 1999 (E36)
    Last Post: 05-05-2007, 11:43 AM
  2. WTB: M50/S50 cam position sensor and crank sensor
    By Lobstrosity in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 02-21-2007, 08:18 PM
  3. So I replaced the cam position sensors and SES light is still on. Help!
    By tynash@yahoo.co in forum 1995 - 2001 (E38)
    Last Post: 01-13-2007, 07:27 PM
  4. Help, Need crank and cam positions
    By M3ANMUG in forum 1975 - 1983 (E21)
    Last Post: 10-01-2006, 01:21 PM
  5. Help! - Cam position sensor problem
    By red740is in forum 1995 - 2001 (E38)
    Last Post: 02-23-2004, 04:23 PM
