Results 1 to 3 of 3
Thread: No heating and heater core question.
    Jan 2018
    lithuania, kaunas
    e36
    Hi. I've already bled the system many times, thermostat is working correctly and I even removed the heater valve and connected the hoses directly - still no heating. I was thinking maybe my heater core hoses are reversed, so can anyone tell me which hose is for inlet and outlet on the single zone (no climate control) heater core?
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Have you tried blowing or flushing water through the heater core? It might just be plugged up.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    washington dc
    Avus Cosmos Calypso!
    or your heater valve is bad...probably most likely. The hoses to the heater core are aluminum. Can't mess that up unless you you hooked up the rubber hoses to the heater valve the wrong way (probably unlikely).
  1. No heat, cold heater core hoses, but car runs fine - any ideas?
    By ZedsDread in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 02-07-2016, 11:57 AM
  2. '95 328i Overheating and no heat from heater. Please Help!
    By muckyhaud in forum 1991 - 1999 (E36)
    Last Post: 10-25-2011, 02:28 AM
  3. fuel and heater core filter related questions
    By coiso in forum 1991 - 1999 (E36)
    Last Post: 12-10-2007, 02:18 PM
  4. over heating and door lock question
    By sickf4i in forum 1988 - 1996 (E34)
    Last Post: 11-01-2004, 12:44 AM
  5. cooling problem and no heat from heater in 325
    By BooDaddy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-05-2004, 09:44 PM
