Results 1 to 4 of 4
    Calgary, Canada
    2009 128i 2009 X6
    X6 e71 rim question
    From my research the stock X6 19 inch rim was 19x9. Will a 18 inch rim fit over the brakes?
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Look at the tire inflation chart on your driver's door/door jamb (or the owners manual). If BMW designed 18" wheels to fit your model's configuration...an 18" tire size will be listed on that tire inflation chart on your door.
    Also the e71 X6 has a split axle hub center bore. The front and rear are NOT the same...the rear is 72.56mm and the front is 74.1mm...so if you 18" wheels fit...make sure that the wheel's center bore is correct for the axle you're mounting the wheel on.
    Calgary, Canada
    2009 128i 2009 X6
    What about the e71 x6m? Is the rear center bore size the same as regular e71x6’s?
    (northeast) Indiana
    Quote Originally Posted by fastasleep View Post
    Yes...the e71 models ALL have the same split axle center bore difference.
    The e70 X5 and e70 X5M are listed separately due to the e70 X5M having a different set up than the other e70 X5 models (it's a split axle center bore difference like the e71 X6 models).
  1. Rims Question...
    By mvaDesign in forum 1991 - 1999 (E36)
    Last Post: 12-12-2001, 05:46 PM
  2. BBS Rim Question -- Please Read Before Moving
    By 318 - KR in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-11-2001, 01:56 AM
  3. New Rims Questions - pls help
    By Ryan325i in forum 1991 - 1999 (E36)
    Last Post: 08-13-2001, 03:26 PM
  4. Rim question invovling weight
    By Josh///M3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-10-2001, 03:17 PM
  5. Rim Question
    By arrogantBMWdriver in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-23-2001, 07:39 PM
