Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Thread: Karies E36 Widebooty Turbo Build
  1. #26
    Nov 2013
    VA
    E36
    Put some brembos on the damn thing if used for autox/track/twisties. Took my car out for the first time around some twisties and hit 100 before a quick sweeping left turn. Didn't think I was going to make it lol.
  2. #27
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    A fancy BBK would not have slowed you any quicker that stock brakes in good condition on that one turn. Might have felt better though. The BBK advantage is after multiple long hard braking in rapid succession.
    Many racers just use good rotors, good fluid, good lines, and good pads on stock brakes. Some also add ducting.
    Last year, I installed Stoptech ST40 front and rear. I had always wanted a BBK and got them at great prices. But in the driving I do, they don’t stop any better than the stock M3 brakes did.
    If you want to feel great bite, buy autocross pads like Carbotech AX6, Hawk HP Plus, G Force R6. They will squeak and dust but feel great. They have a little more heat capacity than stock pads but are definitely not track pads (track pads dont bits well from cold but will keep performing when very hot).
  3. #28
    Nov 2013
    VA
    E36
    Good info here. In the SCCA ITR days, we'd use Hawk blues, super blue brake fluid, good ducting, and some quality blank rotors with good results. Cross drilled/slotted seemed to crack or warp and wasn't worth the additional cost. Keep in mind these cars only made around 230whp on the dyno.
    My non-m turbo doesn't brake as well as my M3/4/5 but it does okay. From what I recall they have smaller calipers, rotors, and master cylinder. I guess it really depends on the type of driving. Track vs spirited. Add 450+ whp or more and things can get hairy.
    I had porsche 996 brakes for the front of my car but they wouldn't fit due to the low offset of the arc 8s. Still haven't driven a car with a BBK to this day...
  4. #29
    Jun 2005
    New England
    E46 330i front brakes bolt onto E36 325 and 328 and are comparable to E36M3 brakes.
  5. #30
    Jul 2014
    Finland
    BMW E36 328i Turbo
    Actually, they Are bigger. Comperes to E46 m3 brakes, only 2mm less thickness. And ofc, "only" one piston in caliber.
    I have those in my Turbo Non-M e36, no recrets What so ever. Way better than stocks.
    Only litle minus, 17" rim is smallest. And Style 32 with e39 specs Fits like 2mm space
  6. #31
    Jun 2005
    New England
    Diameter is a little more, thickness is a little less than E36M3 brakes, which is why I wrote that they are comparable. I don’t know about piston size or brake pad size.
  7. #32
    Jul 2006
    burnaby b.c
    1998 328is 1999 540iT
    that is my current setup. zimmerman rotors with just street pads, need to switch over to some hawk's once its fully sorted out.
    95 318is - m52 powered, 97 328is - M-package, ​01 540iT/6speed
  8. #33
    Jul 2006
    burnaby b.c
    got some work done this weekend. i was able to get the car on the ground, wrap the downpipe, extend coil harness, mount the bumper and align it with new brackets and slides, painted the foglight covers and blacked out the new grills.
    later found out my oem plastic valve cover is crack by the turbo. i've sourced out a OBD1 cover and coils.
  9. #34
    Jul 2006
    burnaby b.c
    small update,
    figured out the massive oil leak it was coming from the oil filter housing rear Orings, powder coated the turbo housing and new valve cover, installed -10 bulkheads for a catch can, retorqued the head while the cover was off, install a RD front strut bar also got that powder coated, had to raise the rear of the hood to clear the fittings on the valve cover and help cooling also.
    yes thats a wheel lug threaded and sealed in the valve cover. lol
  10. #35
    Jul 2006
    burnaby b.c
    bit of an update on this car, looks like the older pictures are gone for some odd reason.
    so just a re-cap
    setup was a stock M52b28 ces spacer/cutring/bw362/rktunes didnt feel like putting anymore than 15psi of boost and renting a dyno for remote tuning.
    so i switched a few things up this year:
    -ditched Stock DME for ECUmaster Classic tuned by my buddy Paulo @AES
    -installed VAG coils
    -BW 366 (bw362 rear seal blew and got a deal on the 366)
    -pinned up my stock harness to ECUmaster
    -100lbs inj
    -my old supra SR3 recaros
    -resized my CCW
    -RTD shifter
    motor still stock but now on just E85.
    car made 567whp @24psi after about 4-5 hours on the dyno sorting all the issues. cleaned the drivability on the street and turned the Boost to 28psi im assuming its closer to 600 or a little over and with boost by gear this car is a riot.
  11. #36
    Jul 2006
    burnaby b.c
    before switch to the BW366 i was able to see the power differences from Stock DME vs ECUmaster
    first sheet is 15psi RKtunes BW362- pump gas
    second sheet is 15psi ECUmaster BW362- pump gas
    third sheet is 24PSI BW366- E85
  12. #37
    Vancouver, B.C., Canada
    '97 M3
    Its interesting that the power is falling off up top on the bigger turbo and was still climbing on the smaller one.
  13. #38
    Sep 2004
    NC
    e36 m3, e39 m5
    any interest in selling?
    11.75 @ 131 6262 2.8l TRM Tuning e36 m3 - 2011 http://dragtimes.com/BMW-M3-Timeslip-23541.html
  14. #39
    Jul 2006
    burnaby b.c
    Quote Originally Posted by chikinhed View Post
    not sure but i wish i was able to push the 362 at 24psi to see what it would make, but it was burning alot of oil so i swapped it out for the 366.
    Quote Originally Posted by dmb882 View Post
    maybe one day! lol
  1. E36 M3 Turbo Build Thread
    By M3 Muscle in forum Forced Induction
    Last Post: 08-13-2016, 10:02 AM
  2. E36 325is Turbo Build Route
    By Xenocide in forum Forced Induction
    Last Post: 10-13-2010, 09:50 AM
  3. E36 M3 Turbo build with lots of pics
    By nowboostedm3 in forum Forced Induction
    Last Post: 09-13-2010, 11:34 PM
  4. e36 M42 turbo build questions Help please
    By bearsbmw in forum Forced Induction
    Last Post: 09-24-2008, 12:39 AM
  5. E36 Custom Turbo Build!!!
    By m3saloon in forum New England - US
    Last Post: 12-10-2007, 07:51 PM
