Results 1 to 7 of 7
Thread: Turboing my BMW 328is
    Sep 2020
    Kimberly
    1996 BMW 328is
    Hello everyone, I was wondering if anyone had any advice while turboing a e36 or the best kit to buy. Has anyone else turbocharged their e36 stock engine? Also I was wondering what you all need to turbo an e36, because I know it would be a lot cheap to source everything out and get some used parts to make this build cheaper in the end.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved to the topic specific discussion area.
    88M3 AW 43k miles Project FS
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    What did you find searching here? I recall a few threads on turbocharging a 328i. What are the specific questions?
    NY
    skateboard
    You’ll want some s52 cams to start, and a cutring head gasket combo(Ces)
    ― George Orwell
    Feb 2008
    Durango/Bayfield CO
    1995 M3 Coupe 5pd
    The answer to the question is yes. Many people have turbocharged an unopened M52. It is suggested to keep it mild, <400 hp and it will likely last a little while. Push it toward 500 and above and things will break. Abuse will break anything.
    There really is no "best" system since individual goals and parameters are infinite. There are only a couple of "kits" tailored to the M5x engine. Most successful builds are pieced together from quality parts and selected through tons of research. The information is readily available and free. Just read a few, or dozen, build threads.
    Since you are new here, the info is in the stickies on this Forced Induction forum. The search function is your friend.
    "Budget" builds quickly exceed expectations by DIYers, by the time you refresh the cooling system, upgrade the clutch, properly vent the crankcase, get appropriate mounts. The little bits add up.
    I know not everyone wants to take the time to learn all the aspects of their car, as there is a TON of things to consider and learn in this endeavor. In that case, just take your car and about $20k to a reputable race tuning shop and tell them to turbocharge it.
    Tom
    Currently 1995 M3 manual coupe, 1993 325is
    Past cars
    2003 530i
    1998 528i
    1995 530i
    1988 528e
    1988 535i
    1987 2.7i
    1972 2002
    Sep 2004
    NC
    e36 m3, e39 m5
    TRM has a great turn key kit with tuning. Each custom build is just that, custom and every setup on this forum is 1 of a kind. Cheers and good luck!
    11.75 @ 131 6262 2.8l TRM Tuning e36 m3 - 2011 http://dragtimes.com/BMW-M3-Timeslip-23541.html
    London,Ont, Canada
    1999 328is & 1997 328is
    ill try and fill you in as I go but i'm currently sourcing all the parts to turbo my 1999 328is e36, I plan for 375 hp to the wheels in the end. so far I have collected
    -Precsion Turbo 5858 e housing t3 flange .82 ar housing -direct
    -Mishimoto intercooler 2 1/2 in and out -direct
    -Turbosmart Wastegate 38mm -direct
    -Tial Q BOV 50mm - ebay
    -Oil feed line from Rally Road
    -Oil Return AN off ebay
    -Black intercooler piping 2 1/2 with silicone hoses and clamps off ebay
    -oil catch can off ebay
    -Cometic gasket .120 thickness - direct
    -ARP Head Studs- direct
    -255lph Fuel pump
    -alum Rad Mishimoto amazon deal
    -New Victor Rinz Gaskets- work deal
    -Bunch of DEI Reflect a Gold heat but also cool looks
    -DEI Exhaust wrap
    Plans are CX racing top mount turbo manifold, and for a tune either VEMS, Rally Road, RK Tunes or TRM i'm on the fence on what one to get
    99 328is daily 97 328is Track Baby
  1. bmw 328i e36 1998 Turbo
    By ecastpro in forum 3 series & Z Series
    Last Post: 08-27-2012, 11:07 AM
  2. E36 FT 1996 BMW 328is Turbo
    By Koselowiec in forum 3 series & Z Series
    Last Post: 02-19-2011, 12:29 PM
  3. Replies: 40
    Last Post: 06-29-2010, 07:50 PM
  4. BMW 328i AC SCHNITZER TURBO 512hp
    By CrazyE36 in forum 1991 - 1999 (E36)
    Last Post: 02-10-2010, 02:38 AM
  5. bmw 328iS vs Beetle VW Turbo (S)? its FAST!!!
    By mifslim in forum Kill Stories
    Last Post: 05-22-2007, 05:33 AM
