Results 1 to 10 of 10
Thread: Chirping/Hamster wheel sound from dash?
    Apr 2017
    West, USA
    1997 E36 M3
    Hey guys,
    This weird noise just started happening in the past week. There is this bird chirping/hamster wheel noise coming from the front of the car, maybe by the dashboard? I cannot isolate its location, but it only happens at 55mph+ then goes away when I slow down to cruising speeds. It also does not go away if I apply the brakes (from above 55 mph) and is not RPM dependent. I have tried rattling trim pieces in the interior and nothing seems loose. I was reading somewhere that it could be the bearings within HVAC blower unit but it makes the noise regardless if the fans are on or off. The squeaking noise is driving me nuts! Any input appreciated
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    HVAC unit has a tiny blower motor in it too. You can see the vent and thermistor for it in the open mesh beside the LCD screen. It’s possible you are hearing that motor. It runs regardless of HVAC power and collects all sorts of dust/dirt.
    Apr 2017
    West, USA
    1997 E36 M3
    Quote Originally Posted by Braymond141 View Post
    Thanks for the response. If that is the interior fan that keeps running ~15 min after the engine is off, that one sounds normal. The chirping sound definitely sounds rotational though. Kinda stumped since it only happens at highway speeds.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by Mileage View Post
    I had a similar noise coming from my HVAC blower motor. It got to the point where it would chirp whenever I turned the car (the gyroscopic forces made it push on its bearings and chirp when it was on and I'd turn the car). I was able to shoot some lubricant in there and quiet it for a good 50k miles before it finally died.
    A open the hood, remove the cover, and see if you can get a shot at that fan (a youtube DIY would help you see where you should be trying to shoot the stuff). Be careful though - whatever you shoot in there will obviously be blown right into the cabin.
    IF that worked, it would at least tell you that the blower was indeed the problem.
    washington dc
    Avus Cosmos Calypso!
    blower motor
    Jan 2006
    Oakhurst, CA
    I’m not seeing how a blower motor off would chirp still. They also typically only chirp when cold and quiet down when warm.
    Apr 2017
    West, USA
    1997 E36 M3
    Quote Originally Posted by blckstrm View Post
    I will dig under the hood tonight and spray some WD-40 on it. I want to eventually delete my heater core (track car) so may remove it altogether at some point. It's just one of those noises that drives you up the wall!
    Quote Originally Posted by scooper View Post
    blower motor
    It chirps hot or cold. Does the blower motor receive outside air when circulation is turned off?
    Nov 2002
    Westchester, NY
    i get a loud thump from the dash when i start the car as well. do you have that too or just the chirp?
    Apr 2017
    West, USA
    1997 E36 M3
    Quote Originally Posted by RickyN F355 View Post
    Hmm what sort of thump? Wonder if it's the heater valve?
    I only have the chirping noise
    washington dc
    chirping noise bedeviled me for a long time and it would continue sometimes even after the car came to a stop. Replaced the blower motor and noise was gone. Guessing the bearings were done.
  1. Wierd bumble bee sound from dash on '89 535I?
    By 70383roadrunner in forum 1988 - 1996 (E34)
    Last Post: 12-03-2007, 09:44 AM
  2. Replies: 5
    Last Post: 10-08-2007, 01:14 PM
  3. lights shut off then clicking sound from dash ??
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 09-19-2005, 02:04 PM
  4. inconstant hissing sound from dash or rear engine bay
    By c3dy8911r in forum 1991 - 1999 (E36)
    Last Post: 08-15-2005, 02:18 PM
  5. Replies: 6
    Last Post: 06-05-2004, 01:22 AM
