Results 1 to 18 of 18
Thread: Can’t remove factory radio
    Nov 2017
    Grand Haven, MI
    1990 535i 428k miles
    I got the two screws on the sides loose and it pulls out about an inch and then stops. Something seems to be blocking it.
    It’s a 1990 535i and it has the following head unit.
    Moderator and Owner of the Subreddit r/E34
    Nov 2002
    So.California
    1995 M3
    Never had one, but maybe it's in a cage and you need a key to retract the side tabs.
    Walk a mile in my shoes and you are a mile away in someone else's shoes.
    Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Riken Raptors* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
    Coming...nada
    BMWCCA-303681
    Jul 2016
    Brandon
    92 M5
    Should just slide out. Likely the harness plug stuck on something g
    Denver, CO
    Likely just hung up on something, but also make sure you have the two screws loosened all of the way.
    I've loosened them enough to slide the HU out a little bit just to find they needed a little more to completely remove the HU
    Mar 2005
    Long Beach, CA
    93BMW 525i/95 BMW 540i/6
    You can remove the fog light switch and trim piece to get your finger(s) behind the radio. Might help.
    USC Ralph - Long Beach, CA USA
    1989 E34 White 525i (M20) 310,000m (Sold)
    1993 E34 Black 525i (M50) 308,955m
    1995 E34 Calypso Red 540i/6 (M60) 201,254m
    1993 E34 Black 525iT (M50) 138,500m
    Feb 2013
    Kalamazoo, MI
    E34 540i6, E46 323i, E36
    That does seem odd, they’re supposed to pull right out. There are little guns that help hold it in but it looks like you’ve already got them out. Does the stock radio still work?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    NW suburban Chicago
    hiss by my window
    be sure the screws are ALL the way backed out, it takes quite a few turns. Nothing else holds it in.
    Nov 2017
    Grand Haven, MI
    Too everyone who says the screws need to be all the way out. The radio has play and doesn’t seem to have the screws stuck. The radio works. Ill probably end up removing some trim to see what’s up.
    Virginia
    95 525, 93 M5, 05 X5 x2
    Sounds like the harness is getting hung up. You could try removing the air vent on top of the dash and see if you can leverage the radio a bit. You can also try removing the carpeted transmission tunnel cover on the drivers side to gain some access.
    The clamping mechanism on either side of the radio can be temperamental in that they may not fully release even if you have completely backed off the set screw. The mechanism is a metal flap that lays flush with radio chassis when the set screw is all the way counterclockwise. When it's tightened, it pops out and slightly forward to secure the radio. You might try putting some pressure on the radio as tou turn counterclockwise to help the flap release to full contracted position or tapping on your tool to jar it loose. Once you get the radio out, you will see how it works and how it's possible for it to get hung up.
    Definitely an odd situation; I've removed E34 radios many times and never had a problem with removing them. Getting them back in can be fiddly as the harness sometimes gets hung up.
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    You can also just remove the HVAC control unit to get your hand behind the radio. Most probably the harness is catching on something.
    Sent from my LG-H870DS using Tapatalk
    Aug 2012
    Richmond, VA
    95 525t, 94 525, 87 325
    Is there a special tool to remove the two radio screws?
    Nov 2017
    Grand Haven, MI
    Quote Originally Posted by skunka View Post
    Yes but if you shove an allen wrench in there it comes out
    Virginia
    The tool (about $8) fits the five sided screw head. Some use a 2mm hex wrench, but you'll risk stripping the screw head so future removal and installation may be compromised.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Spaceturtle917 View Post
    Yes, like Greg says it is a five sided so called anti theft screw. Easily defeated with a variety of other tools. There is a small flat blade screwdriver in my tool box that "fits" into those screws and has remove all I've ever had, albeit a few tight ones got tore up a bit.
    I still contend that the OP's screws aren't fully backed off. The catches are set about an inch back, right where the OP says he is stuck.
    Virginia
    @Ross: Agree completely with your observation that the screws are likely not fully backed out.
    Nov 2017
    Grand Haven, MI
    Quote Originally Posted by ross1 View Post
    Yeah the screws were all the way out. It was just caught on something. I just gave it a big tug and it came out. Caught on something i just don’t know what.
    Aug 2012
    Richmond, VA
    I ended up using a small flat head screw driver to get at the screws. Whole thing came out easier than expected.
  1. Remove factory radio rear support? Really? How tough is that?
    By Llama in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-26-2017, 02:09 PM
  2. 1987 325 factory radio removal
    By raydog2533 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-12-2008, 12:49 AM
  3. REmoving Factory radio?
    By jcsomerset in forum MINI (Cooper & Cooper S)
    Last Post: 01-06-2008, 01:51 AM
  4. how to remove factory radio?
    By 93bmw325is in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-02-2007, 03:15 PM
  5. I cant remove original radio
    By kikitron in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-12-2007, 02:25 AM
