WANT TO Change Rear Shocks!! Cant get to top of rear shock?? Anyone know how? Soft top leaked and had hard top put in, checked fuses, bay wont open, nothing, stuck, please help
Sent from my SM-N950U using Tapatalk
Inoperable soft top, how get into bay so i can get to top of rear shock, trying to change them. Get to if car was raised? Please help. Stuck.
You would have to open the top manually, which I have know idea how it's done
If you have the hard-top on, I assume the soft top is lowered. You would have to take the hard top off and raise the soft top and stop when the last bow is vertical and the tonneau cover is open. This can also be done manually by pulling the lever under your rear seat (drivers side) which disengages the motors, then open the tonneau, pull the top out of the well, then lift the last bow. You will need to prop the tonneau and the last bow open with something.
Changing the rear shock is simple if you can get the cover open!
- Ken -
Inoperable soft top, how get into bay so i can get to top of rear shock, want to replace rear shocks, many years ago had hard top installed guy unpluged the auto top connection under rear seat, pluged in but it still wont work??? Trunk was closed. Checked fuses. Cant figure out. Did what manual said...pulled lever forward...tryed opening bay, but still locked shut! Please help. I'm stuck
merged all 3 threads and moved to convertible section
1.) You need to remove the hard top.
2.) you need to get the storage compartment lid open. This should happen by pressing the button on the center console. If this does not work, then you can lift the rear seat seatbottom and operate the emergency release. This will disconnect the drive motors and should release the latches (1 left side and 1 right side) of the cover so you can lift it by hand. Then you can lift the roof out of storage so you can gain access to the top of the rear shocks.
At least on the 325i's I've seen, there is a gear disconnect mechanism on the driver's side in the trunk to allow manual operation of the soft top.
Alpine 318ic FTMFW!
The disconnect is really under the back seat, left side of the car.
