Results 1 to 5 of 5
Thread: PDC retrofit
    May 2016
    UK
    01/1992 E32 735i SE
    PDC retrofit
    I would like to fit rear PDC to my 735i. I found this link for the e34 http://www.gunnar525.de/screwings_beta/pdc_einbau.pdf
    Now I want it to look and function as OEM but I was wondering if it would be just as easy using a system from a newer BMW as parts will be easier to come by?
    warwick RI
    E30/E32/F25
    Looking at the pictures the pdc module is the one they use in tons of bmws. The harness they use looks like an early e38 harness as they used to have the 2 pin connector like that. If I remember correctly the sensors are the same size so all you’d need is the mounts for the bumper. They sell universal ones on eBay that flush mount them to the bumper they might work. If you use the newer style you can re pin it so you don’t need a switch it just is switched on by the reverse lights. I retro fit an e39 pdc kit I made from a junk yard car for my x3 works flawlessly
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    original PDC EBA for E32 is here on page 2 https://bmweba.com/tag/e32/
    Park Distance Control (PDC) BMW 7 Series E32, EBA – 01 29 9 788 017 BMW Installation Instructions Technical knowledge of the system is required. Installation time: approx. 4 hours depending on the condition and level of equipment of the car.
    David C has installed aftermarket, here a DIY under Davdi's project notes http://www.e38.org/e32/
    May 2016
    UK
    01/1992 E32 735i SE
    Great link Shogun. I've got speakers on the rear shelf which are or connected to the radio which I guess can be used for the PDC. I'm not interested in fitting the PDC switch on the dash. So can I go for any generic module and sensors? I'd try and go for Bosch or other known brand of sensor just want to know how interchangeable modules and sensors are.
    Found e32 module on eBay £50 more expensive than th newer stuff
    Also would th original system plug into the existing gong?
    Jan 2005
    Japan
    The gong usually has empty slots. Gong pin assignment https://www.youtube.com/watch?v=pxnlJAvyr5s
    T4 Park Distance Control – grounding T4 makes an immediate, quieter, continuous, high pitched tone. http://www.unofficialbmw.com/john/e36_gong.html
  1. PDC Retrofit Question
    By mein 7ner in forum 1995 - 2001 (E38)
    Last Post: 06-04-2010, 04:33 AM
  2. PDC retrofit?
    By boeingroyale in forum 1995 - 2001 (E38)
    Last Post: 10-08-2009, 03:11 AM
  3. PDC retrofit in the Coupe
    By schernov in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-05-2009, 11:48 AM
  4. PDC Retrofit
    By JT///M3 in forum 1995 - 2001 (E38)
    Last Post: 12-25-2006, 01:55 PM
  5. PDC Retrofit.. (park distance control)
    By m477M3 in forum 1991 - 1999 (E36)
    Last Post: 10-19-2006, 01:41 PM
