Results 1 to 13 of 13
Thread: head gasket oil seep
    Jan 2018
    California
    E36
    My S50 has an oil seep from the head gasket. It's really just a small patch of old oil with a damp patch in it on the passenger side near the manifold. Records from the previous owner show it was overheated about 70k miles ago, typical E36 cooling failure BS. There are no noticeable fluid losses issues and no signs of any oil or coolant mixing in either spot.
    What do you make of something like this? Any chance replacing the head bolts can offer a cure? Got the idea from searching other threads.
    She runs like a champ @125k miles.
    Nov 2017
    Adairsville GA
    1994 BMW 325is
    The head might have slightly warped if it overheated. Have you pulled the coils/plugs and checked inside the cylinders? It could possibly just be the gasket, but as has been verified to have overheated I would suspect otherwise.
    If it becomes a bigger issue for you, you can get remanufactured heads for it and have them installed, but it will cost you a bit.
    Wisconsin
    98 328IS 03 325xi
    Are you sure it's coming from the head gasket and not the valve cover gasket?
    Gave away my BMWs, driving a VW and an Audi now.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by jmo69 View Post
    ^ This was my first thought as well. That makes a lot more sense and is significantly easier to either ignore or address...
    Nov 2017
    Adairsville GA
    1994 BMW 325is
    It was late when this was posted, I actually typed out a reply about the VCG before it hit me that he said "Head Gasket".
    Jul 2011
    Austin, TX
    Quote Originally Posted by Deus Ex Machina View Post
    Haha - I think we're all hoping for his sake that it's the valve cover and not the head.
    Jan 2018
    California
    E36
    Head Gasket. As I said, it's not mixing coolant and oil, and the seep has been there a looong time. If I can simply replace the head bolts and fix like the previous generations I would, but otherwise as it's showing no symptoms and it's had this small seep for tens of thousands of miles, I'm wondering if there's any benefit in messing with it? There are no drips, no noticeable oil loss, no coolant loss, nothing but a little patch of oil on the head gasket on the passenger side. I know people get freaked out about it, but the head gasket is separating oil and coolant properly, and the only symptom is a slight oil seep externally, which has been there for a long time.
    I checked with a BMW shop and they didn't seem concerned about it at all. I've never replaced a HG but I know people freak out about it.
    Jan 2018
    California
    E36
    I posted a response but for some reason it's not up. Yes, I'm sure it's a slight oil seep from the head gasket, and it's been there for a LONG time. I'm guessing it started when it originally overheated a bit about 70k miles ago (happened in town, not on the track), as I know it's been there for at least half this mileage with no other events during that time. As I said, there's no mixing of oil or coolant and no noticeable loss.
    Jun 2010
    NY
    1997 328i
    OP, I wouldn't worry about this at all. If cars didn't seep a tiny bit of oil they would be all rusty!
    Nov 2017
    Adairsville GA
    1994 BMW 325is
    I would just ckean it off with a microfiber and some kerosene and roll with it. My VCG has been seeping since before I had the car, the oil loss is very small
    Watch it and take action if necessary. You could always take off the Valve Cover and double check the torque specs on the head bolts, use the opportunity to replace the VCG.
    Jan 2018
    California
    E36
    @Eric93se Thanks, I'm not too worried, just wanted to get some other opinions.
    @Deus Ex Machina I'll try that, might just wipe it off though because the only time I get it in the air it's already hot, don't want to accidentally start a fire with heat from the headers.
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    This is what I'd do. You can install ARP head studs if you really want to get things tightened down.
    Jul 2011
    Austin, TX
    Quote Originally Posted by tr64 View Post
    I wouldn't mess with the head bolts. The "correct" torque is actually a specific number done in the right pattern, then another 90° turn in the same pattern, then ANOTHER 90° turn. I'd worry messing with it causes more problems than it solves.
    Just leave it alone, maybe keep an eye on it.
  1. Head Gasket Oil Leak (Driver Side)
    By Drkspunkyx in forum 2002 - 2008 (E65, E66)
    Last Post: 10-21-2012, 02:40 PM
  2. 1990 325 head gasket oil leak...
    By straitsixe30 in forum 1991 - 1999 (E36)
    Last Post: 06-29-2012, 11:09 AM
  3. Head gasket? Oil in coolant and coolant in oil...
    By Fei in forum 1996 - 2003 (E39)
    Last Post: 01-11-2012, 01:08 PM
  4. fixing head gasket oil leak-318ti
    By onzman in forum Hatchback Haven
    Last Post: 03-21-2007, 05:46 PM
  5. head gasket & oil pan gasket
    By dminiero in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-25-2004, 02:00 PM
