Results 1 to 16 of 16
Thread: Phone mount suggestions?
    Feb 2018
    San Diego, CA
    2001 Z3 Coupe
    I travel a fair amount for work and use the phone mapping function often. I also plug in a headset for talking to keep out excess noise.
    Does anyone have a mount which works well and doesn't interfere with the shifter or the airvent too much?
    Does anyone pull out one of the plugs next to the recirc/AC and hard mount something there?
    Kent, Ohio
    1998 M Roadster
    Proclip
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Another option is Panavise. You don't see anything from the side so it's a bit more stealthy. Had one in my S8 and it was great.
    https://www.amazon.com/Panavise-Cust.../dp/B00020CSXK
    http://www.panaviseonline.com/Panavi.../75103-401.htm
    The link is only for the base...Panavise makes all different attachments for whatever you're mounting...hmm, now I'm thinking of a small tablet mount for monitoring coolant temps and the like. Thanks for making me spend more $.
    Nathan in Denver
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    I bought an iMount on Ebay. It sticks to most anything--dash or windshield. I like to have the phone higher rather than lower so that I don't have to take my eyes off the road as long. The magnetic part of the mount requires that you place a piece of metal in your phone case. Severe bumps in the M will cause the phone to move, but it's never fallen off the mount. That's a drawback. Placing the phone on the magnet and removing it is the advantage.
    https://www.ebay.com/itm/Maker-of-iM...1aw3ii&vxp=mtr
    Wayne
    1998 M Roadster
    1994 Honda ST1100--sold
    2017 Yamaha FJR1300ES
    San Jose, CA
    '11 335is vert, '01 Z3M
    I have the ProClip and love it!
    Arlington, VA
    2000 Z3 Coupe, M Coupé
    I also use proclip but with their IOauto magnetic mounting system. Much better for my needs than anything else I’ve found.
    May 2017
    NW Indiana
    2000 BMW Z3 M Roadster
    Quote Originally Posted by rasmuw View Post
    i use 2 of these, one in each of my cars. As the other poster said, requires a metal plate under the back of the case ( won’t work without a case).
    I like it. Easy to keep the phone at dash level, turn sideways or vertical, etc.
    greg
    Tally Ho
    http://wcwebs.net/johnson
    1988 O'Day 322 sailboat - (unlimited mpg)
    2000 BMW Z3 M Roadster (25 mpg - but who cares)
    2019 Subaru Outback
    (30+ MPG)
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by Tallyho322 View Post
    greg
    So my question is does the suction cup really stick to a textured dash board? Does is come off without leaving a sticky residue or a mark? Does it continue to stick on a hot summer day with the windows up when your car is parked in the sun? Does it continue to stick over a winter night when the temperatures are in the teens or single digits? I've used sticky suction cup mounts before on the windshield, and they end up failing under these extreme conditions--I find them on the floor with all kinds of crap embedded in the silicone sticky thingy from the carpet (of my DD--my Roadster is always pristine and I have a Proclip for that), so I'm very skeptical of one that is stuck to a textured dash. However I'd give it a try in my DD if it really worked--for my DD I currently use a magnetic mount system that is affixed into the CD slot:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    St. Petersburg, FL
    2020 M2C
    I will give another recommendation for Pro Clip. No glue, no suction, designed for our cars. Add the magnet set up and phone is very sturdy.
    Bill
    2002 M Coupe. Steel Gray/Black.
    Feb 2018
    San Diego, CA
    2001 Z3 Coupe
    Thanks all, the advice is appreciated. I'm not gong to nickle and dime this--I'm going for the Pro Clip which will end up being $70 but not mar the interior and look good and be functional.
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    Quote Originally Posted by Mr Bingley View Post
    I've had the same problem in another vehicle with the suction cup letting go from the windshield in heat and cold. That suction cup is rubber vs. the sticky silicone. The iMount is stuck to the plastic in the middle of my dash. I removed it this afternoon to see if it left a ring behind. There is something there but I could clean it off. I tried attaching the mount to the textured part of the dash--the door that covers the passenger air bag. It would stick, but the suction didn't help and it was easy to peel the mount off. The Ebay listing says it will stick to most textured surfaces, but now I have my doubts.
    Wayne
    1998 M Roadster
    May 2017
    NW Indiana
    greg
    on my Z3M, it sticks to the dash just fine.
    on my DD, a 2012Honda Civic Hybrid, the texture on the dash is too much for the suction cup. I had to mount it on a mounting disk that is stuck to the dash with 2-sided tape.
    Greg
    Tally Ho
    2019 Subaru Outback
    (30+ MPG)
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by Henway View Post
    Well, look at that: a question simply put and simply answered--a healthy debate--useful suggestions--links provided--a considered result--that is what this forum is all about. No flaming, no name calling, no ad homonym attacks, no "I know more than you about everything" technical jargon filled diatribes. A nice happy simple thread.
    Sep 2017
    Northeast
    2001 M Roadster
    Shhhhh!.... don’t ruin the moment.
    Sep 2004
    SoCal
    Chariot
    Had the Proclip phone mount and holder installed for a while until I got fed up with passengers knocking it loose due to its location-- console edge. It also scuffed the console leather finish. I've since switched to a panavise mount as s8ilver referenced in post #3 and reused my proclip phone holder. It's much more sturdy, doesn't get in the way, and most importantly sits higher. I couldn't be happier and highly recommend it to anyone looking for a solid mount. Installation was a breeze. I'll take post some photos over the weekend.
    On another note, if anyone cares for the proclip mount, I'll gladly send it your way. Just pay for shipping.
    Greenville, SC
    Several
    These fit the diameter of the cigarette lighter hole perfectly. Phone is horizontal but discreet and simple. Spigen Kuel A2002 Car Phone Mount Magnetic Air Vent 2 Pack Phone Holder for iPhone X/8/8 plus/7/7 Plus/Galaxy S9/S9 Plus/Note 8/S8/S8 Plus/S7 Edge & More https://www.amazon.com/dp/B01C6HSDG2..._vlU4AbGSFYQM7
  1. Factory Cell Phone Mount removal?
    By CRAZY-M in forum 1988 - 1996 (E34)
    Last Post: 11-16-2005, 11:47 AM
  2. Tranny mounts suggestions
    By BETO in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-04-2004, 08:22 PM
  3. E36ers, show off your CELL PHONE MOUNTS/HOLDERS!
    By JuBu in forum BMW Rides & Events
    Last Post: 11-27-2004, 12:07 PM
  4. Cell phone service suggestions
    By Filip75 in forum Off-Topic
    Last Post: 05-11-2003, 03:45 PM
  5. my new cell phone mount for e36
    By meekay in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-15-2001, 05:37 AM
