Results 1 to 4 of 4
Thread: Looking for document on taking our side mirrors apart.
    May 2017
    Ontario, Canada
    335i E93 N54
    Hello,
    I do not have the motorized folding mirrors, just manual.
    They wiggle (have play) so much that I have to reset my mirrors for every drive.
    I wish to take them apart and find a way to stiffen them up, so they don't move about.
    I also don't wish to break them.
    Has anybody seen any information on our side mirrors and their disassembly?
    Thanks!!
    May 2017
    Ontario, Canada
    335i E93 N54
    Bump
    I've read many mirror threads.
    I've replaced my glass with convex, which I'm getting used to.
    I've cleaned the electrical contacts, we'll see if the mirror tilts about any longer over the next few weeks.
    The white wire is clipped (no retraction), was like that when I bought it... will likely reconnect and test/fix.
    HOWEVER,
    I still have the issue of the mirror assembly physically wiggling, which when pulled in a 1/4 inch the glass is not showing me where I need to.
    In the attached picture (borrowed), I've highlighted in a green square a spring, which is where the assembly hinges from.
    Below this is where the grooved base allows the mirror to click into various positions (really just clicks at center point).
    This is where I'm wiggling.
    RealOEM doesn't detail these parts.
    I've found no write up on how to correct this wiggling.
    Does the spring come off in some way, allowing access to play around? (I don't see how)
    Thanks!!
    Jan 2016
    Ca
    2001 525it
    On folding electric folding mirrors when the pivot bolt has been tight we have pushed a bit of vacuum hose in to the gap of the two parts
    May 2017
    Ontario, Canada
    335i E93 N54
    Quote Originally Posted by jclausen View Post
    Fascinating. Between the mirror assembly and what it pivots on, if I understand correctly. I'll explore that. (seems a good idea)
    I cleaned my electrical contacts inside the center piece of the mirror and to date, the mirror has not self adjusted position when opening the doors (wonky memory type thing). Very please with that TSB.
  1. How to take a SIDE MIRROR apart for painting
    By bamaboy473 in forum 1996 - 2003 (E39)
    Last Post: 03-20-2016, 01:03 PM
  2. Looking for documentation on OEM Xenon option.
    By 4drian in forum 8 Series (E31)
    Last Post: 12-03-2014, 04:10 PM
  3. Still looking for an aspheric driver's side mirror
    By WRXEATR in forum 1992 - 1999 M3 (E36)
    Last Post: 09-03-2008, 10:02 PM
  4. Looking for bolt on side skirts...
    By Jennifer in forum BMW Parts For Sale
    Last Post: 03-13-2001, 12:39 PM
