Results 1 to 6 of 6
Thread: Instrument cluster popping fuses
    Nov 2008
    Marietta, GA
    1989 BMW 635csi
    Just recently my instrument cluster is popping fuses, the tach, coolant temp and fuel gauge go out, sometimes the tach wildly pulsates with the fuel economy gauge. What the hell? There is a common thread judging from my research of Bimmer forums on the net. I noticed it’s happened to our cars as well. Has to be a common fix. I noticed that it popped today when I put my manual shifter in reverse or when doing nothing out of the ordinary other times. Pops fuses after parking and I don’t notice until I get back in car and start it. In the daytime with headlights off or on at night. Frustrated! My odometer is out (needs fixing) so now I REALLY have to guess fuel consumption
    Nov 2008
    Marietta, GA
    1989 BMW 635csi
    Anyone ever have this problem?
    May 2009
    Camas, WA
    Euro '85 635csi
    I don't think this is very common, which fuses are popping?
    Nov 2008
    Marietta, GA
    1989 BMW 635csi
    Number 10, now it pops as soon as I turn the car on
    Dec 2004
    CT, USA
    e28, e34, e39
    Check that the backup switch wires located under the shift boot are not chaffing against the body and shorting out.
    demet
    Jan 2012
    DC Metro
    1988 635CSi
    I had a very similar problem not too long ago. I think I had a brief thread on it so you can search. Turns out there is some wiring next to or near the transmission that was rubbing?? and every time it makes contact, it causes a short in the system. I replaced the fuses three times before i took it in for repair. So have a look near the transmission shifter area for some exposed wiring. Good luck!
  1. 88 735i keeps blowing fuse 5, instrument cluster lights out
    By mesallem in forum 1988 - 1994 (E32)
    Last Post: 04-19-2020, 11:42 PM
  2. Fuse 37 (Instrument cluster light) keeps going out
    By specialk5284 in forum 1991 - 1999 (E36)
    Last Post: 06-02-2016, 01:19 AM
  3. o2 Sensor Fuse on instrument Cluster?
    By h2owiz in forum 1982 - 1988 (E28)
    Last Post: 03-09-2012, 04:58 PM
  4. 1997 M3/4 No Instrument Cluster Lighting; Fuse #37 not blown
    By turbotime in forum 1992 - 1999 M3 (E36)
    Last Post: 09-23-2011, 12:50 AM
  5. Dash/Instrument lights popping fuses - Shorted?
    By JBasham in forum 1975 - 1983 (E21)
    Last Post: 09-29-2009, 09:54 AM
