Results 1 to 13 of 13
Thread: Seafoam to flush the engine?
    Jan 2006
    BC Canada
    2000 BMW 323i, 2012 Merc
    Has anyone used Seafoam to flush the engine just before the oil change ?
    https://seafoamsales.com/auto/
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    I use liquimoly oil saver and bg44k fuel additive
    _________
    1980 320i - Kashmir Metallic - Sold in 1993
    1985 535i - Cosmosblau Metallic - Sold in 1995
    1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
    1983 320i - 1982-09 - Kashmir Metallic - Currently own!
    2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
    2000 M5 - 2000-02 Titanium Silver - Currently own!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Don’t bother with the “engine flush.” Change the oil and filter at shorter intervals.
    Jan 2016
    Ca
    2001 525it
    Why
    Jan 2014
    USA
    I use those two products only if the engine is excessively burning oil due to gunned up piston rings. Itherwise I only use 0-40w European Castro oil changed at 7500 mile increments. Why use sea foam? Great question. I personally would not.
    _________
    Jan 2014
    USA
    Iphone spellcheck failure.... gunned up = gunked up ... itherwise = otherwise
    _________
    Feb 2013
    California
    '06 zhp coupe
    I used BG109. https://www.youtube.com/watch?v=CmA4r6Izvns
    I did not do a compression test but the engine seemed smoother. Running Shell T6 oil helps too. I can tell you, my motor is a smooth beast.
    Mar 2017
    Norwich, Connecticut.
    E46,MB,Volvo,Audi,MG..
    Yober.....To answer your question...Yes, I have used Seafoam fuel injection cleaner many times. I used it in my Audi a6 from 90k thru 200k. Whenever after about 10k the engine began to have a rough responce I added a can of Seafoam...and the engine began to run smooth...once again...several times...11 years it smoothed the engine. (fuel injectors build deposits at the nozzle) For diesel engines, more prevalent, we used raw 100% biodiesel to clean the injectors...With gassers, kerosene or modified such as Seafoam. Do it...then report back here your finding. You may have other issues...but start with Seafoam treatment.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    To preclude the need for an injector cleaner buy only top tier gas. See www.toptiergas.com for retailers.
    I had a gas smell in my departed 2001 330Ci. I changed the injector o-rings. The business end of each injector was pristine. Why? I buy nothing but top tier gas. Also, Techron is the best fuel system cleaner, imho.
    Mar 2017
    93 octane....I'd guess most of us use...?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    A modern BMW will “run” on 89 octane gas as the engine gas knock sensors that tell the engine computer (DME) when the engine is knocking (premature ignition). 91 octane is fine in the US as our gas’ octane is the average of research octane and pump octane. Personally, I put Shell premium in my departed E46. I use the same gas in my 2018 M240i.
    Mar 2017
    In my early years..1969-1970's was a higher octane readily available...now some 35 years ago...87 cents a gallon...an it was 'aircraft grade' Sunoco 101...later downgraed to 94 the now 93 octane......
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I was at Virginia International Raceway a few weekends ago getting track time with my M240i. He’s a beast but drinks gas like crazy. I had to buy gas at the track: Sunoco 98 octane! Downside: it was $9 a gallon!
  1. Anyone ever used "seafoam" to clean the inside of their engine?
    By BuchbrunnM3 in forum 1996 - 2003 (E39)
    Last Post: 04-22-2007, 10:57 PM
  2. what to use to clean the engine bay?
    By yod88 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-29-2005, 10:53 PM
  3. where to support the engine and transmission
    By virtualj in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-15-2002, 02:27 PM
  4. Time to clean the Engine Compartment
    By Perks in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 05-30-2002, 02:17 AM
