whats the best solution to fix this rust ?
Cut it all out. Remove all the cancer and leave no piece with any sign of rust behind. Then weld new sheet metal in place, fabrication required, to match original bends ribs and profile. After that, protect with proper coatings. Fix the body seals if there has been moisture getting where it shouldn't.
Sent from my SM-G900V using Tapatalk
Is that the only spot of rust?
