Results 1 to 6 of 6
Thread: Leaking fluid from under the car... OIL full,transmission acting up. HELPPPPPPPPPP!!!
    Apr 2018
    Phoenix, Az
    2005 BMW 645CI
    I just bought a 2005 CI convertible earlier this year. Before the purchase I took it to a shop got it up on a lift and checked the I dercarrage for leaks or anything wrong. Thing was bone dry no leaks nothing wrong. All the sudden a few weeks ago I noticed a golf ball size spot in the driveway. Thought it was oil and started checking around the motor. The leak kept getting worse and worse to the point where now it’s a frisbee size spot on the ground each night. Took it to a local Indy he got under it and took off the plastic undercarriage covers and they were soaked in fluid. Thing is the oil dipstick says it’s completly full. He thought it was leaking from the oil pan gasket and the oil filter but then the transmission started acting up. It would just start to rev uncontrollably high at random and it was like I was in neutral on the street all the sudden. One time I gave it some gas and ended up in limp mode. No codes thrown no check engine light on. Reset the tranny via holding down the gas pedal and it still does the same issue but no longer in limp mode. Could this be tranny fluid not motor oil and could there all the sudden be a leak in the tranny pan or something like that???? Anyone else have this problem and figured it out. I read some things about a valve body in the tranny as well as a metallurgist thing sleeve maybe or something like that. Please help with any advice you have this is my daily driver and I’m beside myself now!! Thanks a bunch
    Mike
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Have a read of this:
    http://www.bimmerforums.co.uk/forum/...3/#post3187817
    ...and don't panic, it probably nothing serious, and if it is the transmission sump gasket that is leaking then that is replaced when the fluid and filter is changed.
    My BMW Repair YouTube Channel
    Apr 2018
    Phoenix, Az
    2005 BMW 645CI
    Transmission
    So since it leaking wjat oart do i habe them rellace. Is here a transmission gasket that needs to be replaced. Do I need a whole New transmission pan and filter or just that little plastic piece that can get a crack in it? IÂ’ve read about that part on a few places now. Also do I need the metallurgic sleeve or socknwhatever itÂ’s called. Should I replace all those other parts while itÂ’s taken apart?.
    Thank you so much for reply im
    stessing hard over this..
    Apr 2018
    Phoenix, Az
    2005 BMW 645CI
    Bump
    Anyone know what exact parts I need to buy??
    Quote Originally Posted by Tylerdurden803 View Post
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Jan 2016
    Ca
    2001 525it
    The most common leaks on the engine are upper timing covers, alternator plate gasket ( they can really puke), vacuum pump and the oil pressure switch below the vacuum pump. The trans pan certainly can leak along with the electrical connector. The car needs to get lifted to inspect it. I would check for faults in the egs ( trans computer)
  1. over heating !! Leaking radiator fluid from under the manifold????
    By krazybone305 in forum 1991 - 1999 (E36)
    Last Post: 06-01-2014, 11:56 AM
  2. Clicking from under the car. Ideas?
    By bmwhighroller in forum 1991 - 1999 (E36)
    Last Post: 05-02-2006, 03:42 PM
  3. Leak from under the car...
    By mikey36m3 in forum 1991 - 1999 (E36)
    Last Post: 01-09-2006, 01:46 AM
  4. rattle rattle rattle from under the car
    By Dinan330ic in forum 1991 - 1999 (E36)
    Last Post: 01-18-2005, 04:59 PM
  5. Noises from under the car HELP!!
    By nicegsxr in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-19-2002, 01:39 PM
