Results 1 to 5 of 5
Thread: 02 M3 S54, P0012, replacing intake cam position sensor
    Apr 2018
    Colorado Springs CO
    2002 BMW M3 Coupe
    In order to access the cam position sensor I need to remove the air intake manifold which is the problem. Iíve disconnected everything required to remove it from the throttle housing yet it wonít budge??? Is there something located underneath that still has to be disconnected? The EVAP vent valve and the vacuum hose have been disconnected.1B1494FA-1CCD-41EA-BF81-6C9E241CE5E8.jpgFC711074-ABEC-496C-A486-1FF01F7858E2.jpg249F722B-C458-43F5-AED6-D8CAF01E67D1.jpg
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Probably need to break the seal between the 6 boots and the throttle bodies. They are probably stuck.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Apr 2018
    Colorado Springs CO
    2002 BMW M3 Coupe
    That’s what I thought, what would be the solution? I’ve tried liquid wrench but that didn’t work.
    Mar 2015
    west chicago il
    I would use a tool like this. Carefully insert the end between the boot and TB and work it around as much of the circle as possible to break the seal.
    Apr 2018
    Colorado Springs CO
    2002 BMW M3 Coupe
    Thanks, hopefully Harbour Freight tools has such a tool. Just had shoulder surgery 2 months ago and the strength won’t be there for another 4 months, thanks again for a solution.
  1. Replacing intake cam position sensor - S54
    By S54_367 in forum 2001 - 2006 M3 (E46)
    Last Post: 04-21-2018, 02:08 AM
  2. Replacing intake cam position sensor - S54
    By S54_367 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-06-2009, 01:11 AM
  3. Replacing a Cam Position Sensor
    By mgrant99 in forum 1995 - 2001 (E38)
    Last Post: 11-29-2006, 10:01 PM
  4. F/S Intake Cam Position Sensor
    By BMW Loe in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 10-31-2005, 01:01 PM
  5. ever replace a cam position sensor?
    By Jasonb1971 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-18-2004, 09:14 PM
