Looking for any assistance out there to help me with my inability to connect with most modules using the scanner I purchased. I get error messages about the IKE & EWE. Only 2 modules are found (the first two but I can't remember what they are..sorry!) Every other modules is not found. Took the scanner apart and pins 4&5 and 7&8 are already soldered. I haven't tried to bridge pins 1&2 yet. I have a 1999 740IL with the OBDII port below the radio, not under the hood. The software and drivers are installed and running okay as far as I can tell. Any ideas?
You likely have a round 20-pin connector in addition to OBD port. You need to be using under hood connector.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
yup, the obd port in the E38 is fairly useless. Use the round plug under the hood
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
Yes,you'll be looking for the round diagnostic port,underhood,
not OBD2 port,underdash.
I jumped 2 - 17 and 2 - 20 in the pacman port under the hood and was able to read more modules than before. Problem is that I still can't read the LCM, which I am trying to reach so I can recode it. Would getting the cable to just read the pacman port be the wisest thing to do and do you think that I will be able to read the LCM from there?
