I am taking my E31 ('93 850Ci) to the Southeast Sharkfest. The car is fairly new to me. I have done about 500 miles since acquiring it. My trip to Spartenburg will be over 700 miles each way. The car came with a great service history and I did a 260 mile test drive on the way home. Everything worked as it should. My question to long term E31 owners: other than making sure fluids are fresh and topped off, tire pressures correct, etc. is there anything to which I should be aware? Are there any spares that should be considered "must have" items. I have a race car, so I know that list can be long. I just want to make sure that Haggerty roadside assistance isn't plan A. The wealth of knowledge on this forum is inspiring.
thanks, Greg
2x 5lb ABC fire extinguishers.
spare accessory belts
spare radiator hoses
high visibility vest
flares
reflective triangles
moving blanket (in case you need to work on your car, it can protect the fender paint & you can use it as a cushion if you need to kneel or lay on you back)
your tools
jack
jack stands
AAA
RADAR detector
price quote shipping your vehicle home, in the event of a failure
I drove mine from Spokane, Washington to Atlanta Ga and didn’t even check the oil. You’ll be okay.
There use to be a Map with several members throughout the States to assist E31's with traveling sickness, Sorry i forgot where mines is, Hopefully someone still has a copy.
After purchasing Eva at 11:00 pm, the next morning I drove her from Miami to Cincinnati in 1 day without incident. Not smart, but got lucky. Definitely not recommended. What you do to get ready for the trip is far more important than what you can take with you. Check everything. Hoses, clamps, belts, fluid condition and levels, tire condition and pressure, spray soapy water on inner and outer tire beads and the valve stems, re-torque the lugs, evaluate any minor leaks, test your alternator, inspect and charge your batteries. Prep your car for this trip like you prep your race car for the most important race of the season. A few of days spent in your garage at home are far better than any time spent on the side of the highway.
Desecrator of all things Sacred
Aux water pump and the hose that connects rear coolant manifold to aux water pump and heater solenoids. The tools to change it, and coolant AND 2 gal water container. You will probably be able to get water somewhere but you'll need a container to carry it. DO NOT drive even 1 mile if you START to lose coolant.
Upgrade you AAA to plus (for 100 mile towing) and get the Waze app. If you're upgrading your AAA, it takes like 5 or 7 days to go into effect, so take that into account. I used Waze on a trip from CT to FL and gave me the heads up every single time the entire drive.
My Cars - 1991 BMW 850i - mine for fun, 1993 Saab 900c - mine for fun, 2008 Lexus is250 - my daily driver, 2003 Dodge Durango - my wife's, 1994 Acura Legend - gave it to kid
thanks for the feedback. I have good a good towing policy with Haggerty. I just hope to not use it! the car came with a very complete service history, so I'm not too worried. I just hate getting stuck on the road out of town. I guess my Alpina B7 has had more issues. It is in the shop for a fuel level sender today. I have Waze downloaded and an updated V1. With a thorough pre-departure inspection, I'm sure that I will be fine. i'll take lots of pics and post when I return.
Greg
Enjoy your trip.
Well Greg, for the 5 years I have had my 850i-92 I have taken my car yearly on a 3.500 miles long trips. Have had a few minor problems such as low oil level, a lose ignition connector. A great car of you do a regular service and follow the instructions in the service manual. This summer it will see some more alps and highways.
Similar story. Bought "Heidi" in Indiana on Thursday, started the 2,000 mile drive to Southern California on Saturday. Overslept Sunday morning in Albuquerque and ended up crossing the Mohave desert at high noon....with the AC on & outside temp of 117 degrees. Oh, with the cruise set at 80. Best drive ever!
Sounds like your maintenance is sound so put that 8er on the road and enjoy the drive.
1993 850Ci.....18 years & 165,000 miles and counting!
You can take a million and one parts, but these days, a cell phone is invaluable.
the car performed almost flawlessly. Cruise control was a bit wonky when I started. it didn't want to resume or reset after disengaging. after a fuel stop, it would work correctly for a while. on the return trip, it worked as designed all of the time. only one other small issue. after idling for almost an hour while we positioned for the panoramic photo shot, it died a couple of times upon restart. it then had a rough idle for a minute before it all cleared up. I'm sure that sitting there running wasn't healthy, but no further issues. I will be back at SESF next year. thanks for everyone's input.
Greg
