Results 1 to 2 of 2
Thread: Cluster failure
    Jun 2017
    Denver, CO
    325xi; 740i
    Cluster failure
    It seems the closer and closer I get to getting her ready for a cross country road trip the more failures I indure.
    Today I started the car and all was dandy, I start driving down the road and my speedo doesn't work yet no trans prog. Then I notice the tach isn't nearly where it should be, I'm in 3rd gear at 500 rpm? I stop the car and restart it and at my usual 500 idle the tach says 100~.
    My thought is VSS for the speedo but the tach? It still runs fine and started within the second like usual no hard cranking. I held the test button on the cluster and all the guages moved and responded.
    New Daily:
    2011 Audi A6 Avant 3.0T prestige. 1 of 368
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    94' BMW 740i 308k miles
    Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
    Sold:
    1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Drive a bit longer, maybe the capacitors were almost at the end of their life, could recharge when you drive. Otherwise http://bmwe32.masscom.net/johan/dash...dash_caps.html
    but yours is a 1994 model and the back plate of the cluster is a blue one, 9/90 -> end = Blue, code plug type is PIC 93C56 and size 2048 bytes, works with Self test + diagnosis via Modic. Code plug is standard EPROM
    this one seldom fails compared to the grey back plate one or the blue one.
    Another possibility could be a blown resistor in speedometer, see my website under fixes>>>>instruments>>>Replace blown resistor in speedometer
  1. SRS Airbag Light; Instrument cluster failure
    By Sean`03///Zed4 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 12-17-2007, 07:46 PM
  2. cluster failure....maybe alternator?
    By jrobie79 in forum 1983 - 1991 (E30)
    Last Post: 09-27-2007, 06:20 PM
  3. Gauge cluster failure...
    By FatJohn325 in forum Exterior Lighting & Body Parts
    Last Post: 02-22-2007, 02:03 AM
  4. instrument cluster failure
    By mindspin in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-17-2006, 07:38 PM
  5. Instrument Cluster failure
    By fun2drive in forum 1991 - 1999 (E36)
    Last Post: 08-01-2005, 02:13 AM
