'00 E46. Kind of a cold morning, but did not want to start up right away. Had to hit the gas pedal some. EML light came on some. Seemed to run fine after that. EML means fuel filter, right?
Sent from my SM-G930V using Tapatalk
Jeremy
2000 323Ci Titansilber Metallic cabriolet
EML refers to a fault in the engine management electronics. Most commonly for a circa 2000 E46 is a temporary loss of throttle body position reading. Its a common issue and often resolved by simply disconnecting the TB, cleaning the contacts with electronic cleaner, then reconnecting. The connector was redesigned shortly later.
Engine malfunction light
