Results 1 to 15 of 15
Thread: Serious intake question
    Dec 2017
    Iowa
    2001 740IL
    If I put on a short ram intake on my 01 740il for an 829mile road trip would it confuse my computer or would it be fine now let me State I’m not looking for power as my car is stock it’s no race car I’m looking for the sound and mileage benefits or would I be best leaving it completely stock? Thanks for replying!
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    You're better off keeping the stock filter. I have the e39 540 AFE modified intake on mine but did a few things along with a tune for full benefit. Simply putting the filter on there won't yield you any benefit and depending on the type of filter you install, if it doesn't have a shield, you'll just be sucking in hot air from the engine bay.
    Dec 2017
    Iowa
    2001 740IL
    I have a sheild made already im just looing for even a slight benefit to it would i end up losing gas mileage do you think? i am curious because i once had a car that lost a significant amount of mileage due to a cai but have had better with short rams.
    Dec 2017
    Iowa
    2001 740IL
    I am very surprised only one person has commented on this subject I would really like to hear more insight if it helps my engine is the m62 2001 year 4.4L
    CT
    E38
    I've run a short ram for years and it makes absolutely no difference except for a nice sound. I just wouldn't run the oiled filters because it's unclear whether they foul the MAF or not - it's just unnecessary.
    E38 M Sport 6 Speed MANUAL
    Kansas City, MO
    2x01 750, 01 740
    No difference other than sound. Good that you have a heat shield already.
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
    Dec 2017
    Iowa
    2001 740IL
    well works for me i love intake sound actually more than exhaust these days! plus dont hear them much in city driving so win win for my neighbors haha
    also i agree with you on the dry filters as i had issues on my 95 yukon i used oiled k&n and they dirtied my maf sensor really bad had to clean 3 times in a year we had a dry season i thought it would be better but i was wrong i also kept my filters very clean but its a long process with oil filters in the first place.
    thanks everyone for the replies!
    Dec 2017
    Iowa
    2001 740IL
    well i forgot to ask one question about the air pump how far in front of the maf does it have to be? and if i remember right it absolutely has to be hooked up correct?
    Everett, WA, USA
    secondary air pump hose doesn't have to be hooked up. I was told it's only for initial startup/cold start so unless your state requires cold start, it's unnecessary.
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    The secondary air pump runs at start up to reduce emissions.
    Air intakes have been discussed many times and the consenus has been that the original intake is pretty well designed, as it takes in air from outside the engine bay. The colder the intake air the better for mpg
    Dec 2017
    Iowa
    2001 740IL
    With the air pump not hooked up and a small filter on it will it throw a code? Or do I block it off?
    Everett, WA, USA
    Unless you live in a dusty area and or your engine is really dirty, a breather filter is unnecessary. You can just leave the hose going into the intake box disconnected/uncapped. It won't serve a purpose but it also won't throw a code.
    Dec 2017
    Iowa
    2001 740IL
    Ok so i put on a short ram and put a rag in the hose to block it off driving car as normal should i be getting false mpg ratings? before filter 20mpg in town now i range 11-15mpg it jumps around mabe it wasnt a good idea anyone have input on this also i must mention i have a brand new maf sensor
    Dec 2017
    Iowa
    2001 740IL
    so the reason i had bad readings was from my MAF sensor failing I replaced it about four days after that (post) I can say the sounds from the intake are glorious, exactly what i was hoping for!
    Dec 2017
    Iowa
    2001 740IL
    Also with secondary air pump disconnected it does throw a code.
  1. Serious Headlight question for E36....
    By Bernanke in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-12-2001, 07:54 PM
  2. Conforti Intake Question...
    By JonUK in forum 1991 - 1999 (E36)
    Last Post: 08-01-2001, 10:06 AM
  3. Cold Air Intake Question......
    By jmciver in forum 1992 - 1999 M3 (E36)
    Last Post: 07-29-2001, 10:27 PM
  4. Custom Intake Question
    By jy630 in forum 1991 - 1999 (E36)
    Last Post: 07-09-2001, 06:44 PM
  5. Intake Question
    By 540Rob in forum 1991 - 1999 (E36)
    Last Post: 03-20-2001, 01:30 PM
