Results 1 to 21 of 21
Thread: Brake Calipers 101
    Feb 2018
    Indio, Ca
    1999 BMW M3 Convertible
    Brake Calipers 101
    Can you guys offer a mini-education on calipers. Im just after reliable stream performance -not track.
    There seem to be either Nugeon. OP, etc in the $50 range or Ate, original Bmw. in the $250+ range.
    Are these parts that are usually rebuilt rather than replaced? What are other brands that offer a good product at an affordable price?
    Sent from my SM-N950U using Tapatalk
    Aug 2013
    1999 BMW M3 Coupe
    Why do you need new calipers? If you just want to refresh your existing calipers, rebuild them for very little $ and a bit of work. You can buy caliper rebuild kits which consist of a new internal o-ring and piston boot. It's also recommended you replace your guide pin bushings (and pins if you want) with new OEM parts at the same time. All told, you can do this on all four calipers for probably around $100-125 in parts (plus you'll need some new brake fluid). If you end up needing to replace any pistons, they aren't too expensive either.
    If for some reason you need to replace unsalvageable OEM calipers, get either ATE or BMW calipers. You can buy rebuilt ones online for fairly reasonable prices.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You can also send yours out to be rebuilt or buy already rebuilt ones.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Bimmerworld sells nice stainless steel caliper pistons for rebuilds. http://www.bimmerworld.com/Brakes/Caliper-Parts/
    Stock steel ones tend to get pretty pitted.
    Rebuilding yourself is a PITA if you have not done before. I'd get someone else to do it or buy rebuilt ones.
    Nov 2007
    Central IL
    E36
    I went with Nugeon rebuilds (from Pelican parts)...and they're fine. For $50 I wasn't up for the hassle of rebuilding mine, potentially finding more issues or causing more issues. (I had one sticking).
    Mine did come with the ///M in the casting, so oem castings.
    **Note, you do send your cores back, so these are essentially having yours rebuilt for $50**
    I also figured if Pelican is selling, with really good service/history, then they can't be that bad. Worst case, they'll work with you. I didn't have to bother...have 50k+ on mine now since
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
    Valencia, CA
    Imola E36 M3 E30 Touring
    Quote Originally Posted by JitteryJoe View Post
    Rebuild process was not that bad in my view. There are far more difficult and annoying jobs people regularly do on these cars in comparison.
    Just buy an extra kit or two, in case you tear the boots, and use a lubricant. Brake fluid is OK if you don't have any paint on your calipers.
    Quote Originally Posted by Moron95M3 View Post
    Hmm I didn't see your post. $50 is completely worth it in my view, and I take back what I said above. I assume the calipers are cleaned too?
    Nov 2007
    Central IL
    E36
    Quote Originally Posted by earthwormjim View Post
    Mine looked just like in the pelican ad:
    https://www.pelicanparts.com/More_In...SVSI=.htm#tab1
    PS no idea why one side is $58 and the other is $46 lol.
    1995 M3
    Feb 2018
    Indio, Ca
    What material is best for brake pads? I want decent braking with minimal dust - especially on the front brakes where I'm going with pagid rotors.
    What are the differences between semi- metallic and ceramic and others?
    Feb 2018
    Indio, Ca
    And does one have to replace all brake sensors (4) at the same time? I have a convertible - are the rear sensors a special length/item as suggested by one of the options on rockauto website?
    Valencia, CA
    Quote Originally Posted by jprottas View Post
    I thought there were only two sensors total, front and back?
    Check realoem.com to see if there's a difference between front and rear sensors.
    By the way, I personally don't suggest changing all 4 brake pads at the same time. Do one axle at a time, since braking for the first 10-20 miles on street pads is pretty terrible. It's pretty unusual to need to change the fronts at exactly the same time as the rears too.
    Aug 2013
    1999 BMW M3 Coupe
    There are only two brake wear sensors, I think front left and right rear. No need to replace them unless they break. Mine are pretty beat but they still work fine, or at least don't throw any codes. I personally don't care whether or not they actually work since I check my brakes pretty regularly.
    Feb 2018
    Indio, Ca
    Is it ok to use two different branded pads ie akebono on the front, and something like the bosch on the rear?
    Valencia, CA
    It's probably OK for street pads, they're not that vastly different when it comes to initial bite.
    Why do you want to do that though? I know both companies offer pads for both axles.
    Feb 2018
    Indio, Ca
    Willing to step up on the front where I get tons of dust...otherwise just trying to save $60. Of the oem pads does any brand have less dust?
    Jun 2005
    New England
    A non OEM ceramic pad is likely to have the least dust.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Probably the last place to save $60 is on the brakes... Just saying.
    Anyway. I'd avoid the Hawk HPS pads, I didn't like them at all, They felt very wooden, with very little initial bite.
    But pads have probably changed since I've had stock brakes.. (12 years with Wilwood superlites...)
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Wow, those are damn good deal for completely rebuilt with new pistons/seals, and a clean/fresh caliper....I was in the process of rebuilding mine, but may just buy those
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Aug 2013
    1999 BMW M3 Coupe
    FYI, if you do buy rebuilt calipers online they'll likely be missing the ///M stamp on them, if you care about such things. One reason why I suggest just rebuilding your calipers unless they are so rusted out as to be unsalvagable.
    Feb 2002
    Orlando, FL
    Quote Originally Posted by TostitoBandito View Post
    Not true....even the ones from Autozone have the ///M in them
    Aug 2013
    1999 BMW M3 Coupe
    Quote Originally Posted by BMWManiac View Post
    Really? I've heard lots of people say the remanu ATE units you get online at ECS or bimmerworld or wherever while being functionally identical OEM parts, usually don't have the M stamp.
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    I bought a set of Nugeon remanufactured fronts several years ago. They had the M logo. I'd say the rebuild job was questionable. One caliper had obviously been dropped - the eyelet where the slider pin goes through was deformed and dented in. This worked ok for stock rubber slider boots but didn't work when I changed to brass bushings. I had to grind a flat on one of the bushings to get it to fit through the caliper. Also, the bleeder threads were super loose and sloppy. This made bleeding a pain in the @ss. In short, the quality of reman caliper you receive depends in large part on the quality of core unit they start with. It can be a crapshoot. I've experienced this with reman alternators too. Knowing what I know now I always buy new stuff.
  1. Removing front brake caliper piston
    By ///M3-=FiN=- in forum 1992 - 1999 M3 (E36)
    Last Post: 09-16-2001, 10:38 PM
  2. oh baby... that red brake caliper!
    By driveit in forum 1991 - 1999 (E36)
    Last Post: 08-11-2001, 05:06 PM
  3. Pics of painted brake calipers?
    By DJ_Vyb in forum 1992 - 1999 M3 (E36)
    Last Post: 06-21-2001, 10:31 AM
  4. Painting brake calipers?
    By The Tick in forum 1991 - 1999 (E36)
    Last Post: 04-27-2001, 08:46 AM
  5. I wanna paint my brake calipers...any tips?
    By xjeeper in forum 1992 - 1999 M3 (E36)
    Last Post: 03-20-2001, 08:26 AM
