Results 1 to 12 of 12
Thread: 2001 e46 M54 gas leak
    Jun 2010
    Akron, OH
    2001 BMW 330i
    Anyone have an e46 that has had a gas leak by the left (drivers side) rear of the car just in front of the rear tire? It is a very slow drip. My tank is full, but the car has not been driven all winter. The drip just started about a week ago. I suspect one of the fuel lines are leaking somewhere near the front of the tank but I can’t get underneath the car for a good look where it is in the garage.
    Has anyone had a similar problem with theirs?
    I appreciate any help with this.
    Thanks.
    Jan 2016
    Ca
    2001 525it
    Remove the low cushion rear seat, remove access panels look at the top of the gas tank where the threaded ring is that holds the fuel pump in or sender check there
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The electric fuel pump is on the passenger side of the car. There is a sucking jet pump on the driver’s side.
    Jun 2010
    Akron, OH
    2001 BMW 330i
    Quote Originally Posted by jclausen View Post
    Thanks, I’ll have a look at it.
    Jun 2010
    Akron, OH
    2001 BMW 330i
    Quote Originally Posted by MarcoZandrini View Post
    Thanks.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Basically, the fuel tank appears to be a single piece, and not 2 separate tanks. Here the link to realoem:
    http://www.realoem.com/bmw/enUS/show...diagId=16_0372.
    Jun 2010
    Akron, OH
    2001 BMW 330i
    Thanks. I’m familiar with the website. Am going to have a look at the car this weekend if I have time.
    Jun 2010
    Akron, OH
    2001 BMW 330i
    Thanks again for the advice. I pulled the rear seat and had a look at the fuel sender locations (both sides). Right side where (I think) the pump is, was high and dry. Left side (where my gas leak is) had a mouse nest in it that was sitting in a puddle of gasoline.
    I cleaned out the nest and siphoned out the gas. Funny thing is that, aside from the puddle of gas, I don’t see where the leak is coming from, especially considering that the car had not been started all winter. I turned ignition to ‘run’ in order to pressurize fuel system and no visible leak.
    So now I am trying to figure out 1) what is the best way to get rid of mice and 2) where that puddle of gas came from...
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Jun 2010
    Akron, OH
    2001 BMW 330i
    OK, I filled up the tank, parked it, and next day there’s gas dribbling down the tank. I’m thinking the gasket around the sending unit needs to be replaced because it only seems to leak when the tanks full.
    Does this make sense or am I overlooking something?
    Jan 2016
    Ca
    2001 525it
    Replace the seal and get on with life, to bad you have a full tank
    Mar 2018
    Millis, MA
    2002 325xi
    *Had
    Lol
  1. 2001 e46 330xi m54 engine oil leak/ excessive oil consumption and smell
    By Extrozeph in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-22-2014, 04:46 PM
  2. 2001 E46 Differential Leaking
    By OVRST33R in forum 1999 - 2006 (E46)
    Last Post: 05-29-2013, 11:49 AM
  3. e46 M54 small oil leak
    By Spektrum in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-20-2011, 03:11 AM
  4. 2004 bmw 325i E46 M54 engine oli leaking form top
    By opnsesame in forum 1999 - 2006 (E46)
    Last Post: 12-06-2009, 12:18 AM
  5. 2001 530i gas leak
    By fojekl in forum 1996 - 2003 (E39)
    Last Post: 04-06-2008, 07:30 PM
