Brake booster rebuild kits and intake manifold gaskets back in stock
Also still have a few sets of fuel injectors available. Please use email rather than PM, max@finemotoring.com. Thanks
Silicone Intake Manifold Gaskets $120
Hydraulic Brake Booster Info and Repair Instructions $120
When rebuilding the booster, use grease on the parts; ordinary axle grease is fine, but avoid silicone or glycol. Be very careful with the input shaft seal, both putting it in the groove and when pushing the shaft back through. Use a little gasket goo on the seal that goes in the cone. If you have an early car other than an e31, don't discard that white nylon split backing washer that fits behind the input shaft o-ring, you need to re-use it. There’s an extra o-ring in the kits in case you have an earlier booster retrofit.
Brand new fuel injectors for M70/S70/M20 engines (Discount for V12 owners, $36 each)
How come the middle half of any project always takes the most time?
