Results 1 to 14 of 14
Thread: E36M3 Rear Caliper Dust Seals
    Jan 2002
    North Augusta SC
    Does anybody sell dust seals that hold up to track conditions? I’m running Stoptech calipers up front, and the gray silicone dust seals last for years. The black rubber seals on the OEM rear calipers are usually toasted after a couple of track days.
    '95 M3 S54 Track Toy
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    ithaca Ny
    95m3/97m345/powerstroke
    Weird, mine last a few seasons. What pads you running?
    Jan 2002
    North Augusta SC
    Quote Originally Posted by Pat533i View Post
    Mostly PFC08. I may have exaggerated a little bit, but they sure don’t last long. I’m also running a few (like 100) more HP than stock, so they get worked pretty hard.
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    NeilM is online now Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    The rear brakes do less work, but they get much less cooling too. The calipers get hot and the dust seals fry. Short of going the BBK route the resulting caliper rebuilds become a cost of doing business.
    Which is why adding the StopTech rears is nice (although not exactly wallet-friendly). A side benefit is that the pads and friction rings become front/rear interchangeable, which is nice for managing those consumables.
    Neil
    96 M3 — 4-wheel StopTechs
    Jan 2002
    North Augusta SC
    I’ve been considering that. I expect the rear pads last forever with the ST setup, too.
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    Marietta, GA
    95 M3, 87 535is
    For a track only car, dust seals aren't essential.
    Fort Wayne, IN
    Quote Originally Posted by jayjaya29 View Post
    True, although with stock ferrous calipers and pistons that'll call for ramping up the inspections.
    Neil
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    There is a big difference in longevity between the replacement boots from autozone or wherever and the BMW or ATE parts. I bought the cheapo ones once and they dried and cracked after a weekend or two as compared to a season or two for the BMW or ATE versions.
    Jan 2002
    North Augusta SC
    Mine were whatever came on the Nugeon rebuilds. I’ll try the Ate bits and see what happens. Still thinking about going the ST route...
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    ithaca Ny
    I run 08’s too. Rebuilt with genuine, no problems. 265whp and Hoosiers
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    I can't find anything that lasts more than a couple seasons. $2.50 Centrics seem to give up the ghost at about the same rate as the overpriced OEM. Fortunately it's not hard to pop on a new set.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Are you using OEM ATE dust seals?
    I haven't had a problem yet, I'll inspect mine and see how they look.
    Jan 2002
    North Augusta SC
    Just received a supply of Ate rear seal kits, along with seals for my front Stoptechs, so that should keep me busy this evening...
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    When I had stock calipers any dust seals I used (including ATE) would fry quickly. I just got in the habit of rebuilding calipers a couple times a year - knowing that they take a lot of heat and also that dust seals with holes allow moisture in that causes rust.
  1. E36 E36 M3 REAR Brake Caliper Dust Seals
    By kjb374 in forum Brake Kits, Rotors & Pads
    Last Post: 12-21-2010, 12:10 AM
  2. Replies: 4
    Last Post: 06-13-2010, 02:15 PM
  3. E36M3 rear brake caliper anti-rattle clip
    By SamGrant951 in forum BMW Parts Wanted
    Last Post: 12-05-2008, 12:11 AM
  4. FS: E36M3 brakes front and rear - calipers with carriers
    By Krank in forum Brake Kits, Rotors & Pads
    Last Post: 09-09-2008, 02:39 PM
  5. Aftermarket brake calipers without dust seals
    By RichP in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-03-2004, 09:13 AM
