Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: Best Turbo for 500WHP S52 - GTX3582R Gen 2?
  1. #26
    Huntsville, AL
    95 M3
    Having the the EWG in addition to the IWG gives good boost control but at higher boost the IWG is blowing open. A higher pressure WG spring would work but I need to have 13-14 psi spring pressure for the WI failsafe. I’m going to use the four port solenoid to hold the WGs closed until target boost is met. 25 psi with the EFR9180 feels great and then it drops to 21 psi which isn’t bad but not as great.
    Have you measured EBP on your new setup?
    WOT
  2. #27
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    So I'm assuming one could run just an IWG EFR on the Steedspeed manifold assuming they have the higher boost spring in the wastegate can?.....and pluged the EWG Vband?
  3. #28
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The IWG is available only with the 0.92 housing. I doubt it would control boost, and if you run an EFR too fast you can damage the turbine. If you want to run a 9180 flat out maybe buy the 9174 instead — the turbine wheel might hold up better.
    CES runs an EWG 9180 with 1.45 housing and I think they said they can get as low as 22 psi with just a 44mm external gate but you should double check that psi — the number 16 psi also pops into my head, which would seem hard to believe but maybe the big housing slows the turbo down enough.
  1. Best turbo for 400-450whp range?
    By 1fast328i in forum Forced Induction
    Last Post: 03-15-2006, 09:39 PM
  2. Best Turbo for Low RPM Boost?
    By tonymasone in forum Forced Induction
    Last Post: 11-13-2005, 03:38 PM
  3. Help me find the best turbo for 23psi - Thanks!
    By danpinder in forum Forced Induction
    Last Post: 07-05-2005, 09:45 AM
  4. best turbo for my bimmer and other questions
    By redforcedbmw in forum Forced Induction
    Last Post: 03-11-2005, 02:18 PM
  5. Best turbo for a 95 m3
    By LukeG in forum Forced Induction
    Last Post: 09-11-2003, 12:45 AM
