Results 1 to 23 of 23
Thread: Removal Dashboard instructions
    Sep 2014
    1988 BMW 635csi
    Any E24 owners, enthusiast that have videos, manuals or something to remove my dashboard and fix my odometer? I’m trying to prepare my car for The South Shark Fest at the end of the month.
    DVO
    St. Louis, MO
    '84 635 Euro/'14 328i GT
    There's a downloadable guide in the How To section of www.odometergears.com . They're a SESF sponsor and will probably be the ones helping with parts to fix the odometer so it's a great resource!
    Lou. Ky.
    87-635 '78-R80/7 '96-960
    I don't know if it's the case in every dash replacement. But helped with my son's 6. We were unable to get the 4 clips where the dash clips into the fire wall after trying for a significant amount of time. Ended up having to pull the windshield. Only compounding the job.
    Sep 2014
    1988 BMW 635csi
    Thanks so much guys. I will work on it tomorrow and let you know.
    Sep 2014
    1988 BMW 635csi
    Thanks for the heads up. Hopefully no need to do that.
    May 2009
    Camas, WA
    Euro '85 635csi
    Are you trying to remove your instrument cluster, or the whole dash? Instrument cluster is an easy job.
    Sep 2014
    1988 BMW 635csi
    Instrument cluster. The miles stopped working and the abs, brake and oil light at the right below turn on and off (intermittent). Any advice for those issues?
    Oct 2017
    Zagreb, Croatia
    '78 633CSi, '81 635CSi
    For the cluster you remove the steering wheel, 2 screws from underneath that hold the steering mechanism/lock (is falls down a few centimeters).
    Then you should be able to pull the cluster off after you remove its screws.
    Sep 2014
    1988 BMW 635csi
    Thanks Leonardo
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Quote Originally Posted by pacho1865 View Post
    Thanks Leonardo
    Also, Since you have an airbag car be sure to disconnect the battery,then the airbag connector under the steering wheel and connectors in the glove box so you don’t blow yourself through the window . I also second Leonardo’s recommendation about the screws holding the column up. Definitely saves you a few hours.
    Sep 2014
    1988 BMW 635csi
    Thanks Hakeem. I unplugged the battery and stirring wheel. Is the glove box connection necessary as well?
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Probably not mandatory but just in case.
    Sep 2014
    1988 BMW 635csi
    Ok, thanks so much.
    Sep 2014
    1988 BMW 635csi
    Hey guys, I got stuck with this connector. Do you think is welded?
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Nope, it’s not welded. I had the same problem, You just have to get back there with a flat head screw driver and it’ll come off.
    Sep 2014
    1988 BMW 635csi
    I got it! This is where I am now.
    Sep 2014
    1988 BMW 635csi
    Hey guys, I’m putting the cluster back and I got a connector that I don’t know where it goes? Here is a pic
    Sep 2014
    1988 BMW 635csi
    Any help would be appreciate
    Sep 2014
    1988 BMW 635csi
    Odometer issue.
    Hey guys, I put the cluster back and still does not work.
    I changed the 3 gears. E1 the smallest gear was broke. Are there any suggestions?
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Odometer issue.
    Hopefully you figured it out. Wish I could help but my odometer hasn’t worked since I got my car.
    Sep 2014
    1988 BMW 635csi
    Hakeem, thanks for getting back to me. I haven’t yet but I will.
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Is the OBC working? When I removed my cluster my OBC wouldn’t work and it turns out I swapped the blue/white connectors that plugs in the back. I think it might be the same issue.
    Sep 2014
    1988 BMW 635csi
    Hey sorry for the delayed response. On board computer works well, If OBC means that. I’ll remove it the cluster and start again.
    The ANTI-LOCK light is driving me crazy. It’s on all the time. Any ideas?
  1. How to remove dashboard !! HELP !
    By atlantisvip in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-14-2006, 08:37 PM
  2. How To: Remove Dashboard
    By jrhaile in forum 1991 - 1999 (E36)
    Last Post: 06-23-2005, 09:23 PM
  3. Removing Engine Instructions?
    By datboibrad in forum 1991 - 1999 (E36)
    Last Post: 04-02-2005, 11:15 AM
  4. Replies: 2
    Last Post: 01-20-2005, 12:37 AM
  5. seat removal/repair instructions
    By ckdc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-26-2004, 10:20 PM
