Hey guys, im new to the car scene and I own a 198 BMW M635csi. I want to learn more about my car and problems (if I haven't had them already) That are common with the car.
Welcome. Have a good look around here, and also at http://bigcoupe.com/phpBB2/index.php
Good luck with your Cali smog check BTDT.
If you don't know the motor history, the biggest areas of concern are:
valve spring recall/replacement
timing chain rails potential degradation
and the steering box mounts tend to crack.
Post pics.
Cheers,
Ray
add thrust arm aka upper control arm bushings causing wheel shimmy, which can be aggravated by non stock wheels and or worn ball joint bushings and odometer gear failure
