Originally Posted by
honfar
I'd like to code sports+ mode onto my 2014 328xi, would this be possible? I currently have eco pro, comfort, and sport, but I'd like to have sports mode and DSC off at the same time. I found this info in an old thread:
Do the following:
Kombi => 300C ECO_FDS =>Function
FDS_MENUE_TEXT_1=> menue_3
FDS_MENUE_SIGNAL_1=> menue_3
FDS_MENUE_TEXT_2=> menue_3
FDS_MENUE_SIGNAL_2=> menue_3
FDS_MENUE_TEXT_3=> menue_3
FDS_MENUE_SIGNAL_3=> menue_3
FDS_MENUE_TEXT_4=> menue_3
FDS_MENUE_SIGNAL_4=> menue_3
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
ICM/IcmKod_B_S2TBA -> verbaut
It will activate sport+ and sport transmission )))
Or you also could add 2TB option and delete 205 in salapa element
When I go into sports mode and switch to manual my cluster reads "S1, S2, S3...", does this mean I have SAT already? I do not have paddles so what would I need to code in order to have sports+ available in the menu and also not have the car outputting any errors? I was going to use bimmercode unless something else would be better for this.
Also, what's the difference between 2TB and 205?
Thanks in advance for any help
@honfar,
I also have a 2014 328i and I have coded it to allow me to use Sport+ mode (which basically is Sport mode without DTC). Here's what I coded:
In CIMQL module:
- 3000 Daten> ICMKod_B_Sportlenkung from nicht_verbaut to verbaut
- 3000 Daten> ICMKod_B_S7ACA from nicht_verbaut to verbaut
- 3000 Daten> ICMKod_B_Sportindiviualisieber from aus (00) to ein (01) (this enable the sport mode configuration -- that is you can select steering, suspension or both)
In HU_NBT module:
- 3000 HMI> Macro_FDS from only_popup (00) to popup&configuration (01) (also enabling sport mode configuration)
I did that some time ago and it has been working fine for me.
Hope that helps
Al
2014 328i |Technology |Premium |Cold Weather| Harmon Kardon| Manual|
BMW CCA
