Results 1 to 9 of 9
Thread: Brey-Krause Driver Side Seat Mount R-9242
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Thumbs up Brey-Krause Driver Side Seat Mount R-9242
    E36 Brey-Krause Driver Side Seat Mount R-9242
    R-9242 Driver Seats Between 426mm to 410mm wide at mount point
    This mount when all the way back and combined with my OMP HTR-R is too close for my height, 6'2".
    I've switched hardware to give myself more room.
    Includes the eight shims for fine tuning height adjustments.
    Material: 11 gauge, type 304, stainless steel
    Finish: Powder-coated in durable black wrinkle-finish
    Weight: 6.5 lbs
    Models: Mounts seats with a width between 426mm and 410mm to BMW E36 floor
    Installation:
    Miscellaneous: Because of their different seat mount points, Sparco seats tend to sit high with the R-924X seat mounts while Recaro seats mount low. We recommend tall drivers use Recaro seats and short drivers use Sparco seats. Average height drivers should be fine with either.
    -The R-924X line of seat mounts is the clean, simple, light weight, and strong way to attach your fixed back bucket seats directly to the floor of your e36 BMW. Instead of using long slots and tons of holes to create a one size fits all generic solution, they are made specifically to fit in a small number of car chassis and work with a limit range of seat sizes to create a precise fit.
    -The R-924X seat mounts bolt directly to the floor using the stock BMW hardware. No floor mount adaptor or alternation to the car is required.
    -The R-924X seat mounts provide all necessary mounting locations for the 3 point seatbelt. These mounting points can be used to mount lap belts for the 4, 5, or 6 points as well. Sub strap mounting is possible when using the R-9259 Sub Strap Mount (sold separately). This system allows for the use of the stock 3 point seat belt in conjunction with 4, 5, or 6 point harnesses.
    -Due to not using a floor mount adaptor or sliders, the R-924X seat mounts allow your seat to be mounted lower than any other mounting solution we've seen.
    -The R-924X seat mounts weight 6-7 lbs per seat. Traditional adaptor/slider/mount/belt mount point solutions can often weigh in excess of 20 lbs per seat.
    -The rear seat mounting holes, which take the majority of the load in a crash, are not slotted, adding considerable strength.
    -The R-924X seat mount line has been tested and certified by an independent lab to handle the types of forces required by the National Highway Traffic Safety Admin. DOT and SAE J385 Rev.MAR 95, Motor Vehicle Seat Belt Anchorages-Performance Requirements.
    -If a fire extinguisher mount is desired, all R-924X seat mounts include provision to attach the R-2295 fire extinguisher mount. This mount can be used with either our R-9520/9530 quick release mount or the stock 3 lb Amerex bottle mount.
    Feel free to ask me any questions.
    I ship first thing next business day via UPS/USPS and will message you the tracking number the same day.
    I've been selling stuff online for years, you can see my 130+ iTrader on EvoM here: http://forums.evolutionm.net/itrader.php?u=65532
    Asking SOLD includes FREE shipping and PayPal fees to the lower 48 states!
    :drink:
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Still available
    Open to offers
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Mar 2017
    Oahu / Los Angeles
    S54 E36
  1. Brey-Krause Outside Side Seat Belt Mount Kit
    By Tronix in forum Race Cars & Track Parts
    Last Post: 12-14-2009, 11:02 AM
  2. For Sale: Brey Krause fire extinguisher seat mounting bracket for E36
    By turbo mike in forum Exterior Lighting & Body Parts
    Last Post: 09-21-2009, 07:22 AM
  3. For Sale: Brey Krause fire extinguisher seat mounting bracket for E36
    By turbo mike in forum Race Cars & Track Parts
    Last Post: 09-20-2009, 01:21 AM
  4. For Sale: Brey Krause fire extinguisher seat mounting bracket for E36
    Last Post: 06-21-2008, 11:39 AM
  5. For Sale: Brey Krause fire extinguisher seat mounting bracket for E36
    Last Post: 06-19-2008, 08:39 AM
