Results 1 to 4 of 4
    Jun 2004
    Earth
    X5 & 540i Msport
    E53 2002 X5 4.4 257k KMS P0021
    Hi Folks, wife came home today said the check engine light was on. I hooked up my scanner and a P0021 code came up Intake Camshaft Position Timing - Over - Advanced (bank 2).
    It's running fine slight rapid ticking coming from passenger side (sounds like an injector?) and only heard with the engine cover off. I erased the code took it for a quick spin vanos kicked in like normal and code is gone. (for now anyways)
    No oil leaks, thinking it is a solenoid to me, am I on the right track? I'm in full denial about the TCG as there is no chain rattle.
    Thank you for your advice and input.
    Mike
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    You got the timing guide warning,
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Jan 2016
    Ca
    2001 525it
    Yup 0021 is the one
    Jun 2004
    Earth
    X5 & 540i Msport
    Error code came back today, drove about 700 KMS since I erased the DTC with out any issues. The Engine is quiet and running fine. If it's the guides then it won't be repaired so hoping it's a solenoid or sensor issue.
    I erased the code again and will see if the DTC comes back.
    Thank you
    Mike
  1. Bmw x5 e53 2002 3.0 lift kit?
    By charlesx5 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-14-2019, 08:37 AM
  2. Halo Upgrade E53 2002 x5
    By vthoma11 in forum Lighting sponsored by BAVToys
    Last Post: 09-30-2014, 02:17 AM
  3. Replies: 5
    Last Post: 03-16-2012, 08:49 PM
  4. 2002 X5 (E53) Glove Box Stuck shut/locked -- please help???
    By hmwe46 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-11-2012, 05:14 PM
  5. 2002 X5 Water pump (E53)
    By DeitersE39 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-13-2010, 11:27 PM
