Results 1 to 12 of 12
Thread: '00 323Ci radiator light comes on sometimes
    Jan 2018
    Sachse, TX
    several
    See attached. Not sure if this is saying my thermostat is going out or low coolant. It goes away soon after starting. Does not always come on. Temperature gauge goes to about the middle when warmed up and stays there. Just replaced the radiator not long ago. Replaced upper and lower hoses also. What do you think this light means?
    Sent from my SM-G930V using Tapatalk
    Jeremy
    2000 323Ci Titansilber Metallic cabriolet
    Nov 2013
    Westlake,La
    1994 E34 530i
    Coolant could be a little low, or the sensor in the coolant reservior may be going bad
    Sent from my SM-G892A using Tapatalk
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by Ernie D View Post
    Thank you!
    Jeremy
    Jan 2016
    Ca
    2001 525it
    And fix your right headlight or turn signal bulb, the bulb out indicator is on
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by jclausen View Post
    Yes. The bulb is fine. I think it is the socket itself or something more fun I need to trace down.
    Jeremy
    Feb 2013
    Lynnwood, WA
    02 325i
    I replaced my expansion tank and the indicator light comes on randomely. The sensor that came with the tank kept light on all the time. I reinstalled the original and now only sporadic.
    Dec 2013
    Chicagoland area
    EXOTICS
    Try bleeding the system,
    if still sporadic,replace with BMW Genuine sensor.
    Mar 2018
    West Warwick, RI
    2002 BMW 325xi
    My 325xi has this issue with 3 of its lights. Both headlights and one taillight. The PO put in new HID's and angel eyes and I doubt he wired them correctly because the "bulb out" light on the dash is always on, but the headlights work fine. As for the taillight, I noticed that the rear brake light on the side that the dash indicates, lights up in the wrong spot. I doubt physically placing the bulb in a wrong spot would cause the computer to think it's out unless the PO put the bulb in the wrong socket. It's a bit of a mystery to me, and I know nothing about electrical or wiring apart from PC's (I'm a computer nerd; not an electrical nerd/mechanic). Any ideas on what I can do?
    Jan 2018
    Sachse, TX
    several
    Temperature stays good. Light goes off after it warms up. Where is the sensor located?
    Jeremy
    Apr 2016
    Philadelphia
    1997 m3
    Its located on the bottom of your expansion tank. I would check coolant level before a cold start. That's when the system is at its lowest.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by Ateyourv8 View Post
    Check it in the reservoir? I need to replace my cap.
    Jeremy
    Jun 2017
    Texas, USA
    '04 BMW 325 Ci blk cpe
    when my temp/rad light came on after I started using the heater, it was that there was air trapped in the heater core and as soon as I turned the heat to full blast and bled the system I no longer got that annoying random rad/temp light flicker...so do a rad bleed/refill and you should be fine. god luck
  1. ABS, Brake and traction control lights come on....sometimes
    By Jon540i in forum 1999 - 2006 (E46)
    Last Post: 12-05-2011, 11:02 PM
  2. ABS light coming on sometimes
    By DmcL in forum 1983 - 1991 (E30)
    Last Post: 05-04-2010, 02:12 AM
  3. ASC light comes on randomly sometimes and will not shut off
    By dAPEX in forum 1992 - 1999 M3 (E36)
    Last Post: 08-12-2007, 07:31 PM
  4. ABS Light comes on sometimes
    By Nicklle36 in forum 1991 - 1999 (E36)
    Last Post: 01-10-2007, 03:26 PM
  5. Replaced Radiator Now no Heat & Check Eng Lights Comes on
    By Wilhelm8 in forum 1991 - 1999 (E36)
    Last Post: 03-23-2006, 11:53 PM
